Garrett GT4088 Vs GTW3476
Fr3akyR33
 Share
1 hour ago, Mick_o said:
Lol .63 on a 3L?! You have alot to learn young Jedi... Measure your turbine pressures or flog your car for a while and see how long the head stays on it with a .63?
Depends what your doing with it, mines not corked at all, keeps making power past 7500rpm, its a street car and wont see a track to be flogged non stop, if its only street car then id rather it have more low end as id rarely hit 7500rpm on a local street.
I guarantee you wont make more low end with a smaller turbine.
Trying to bring boost on early doesn't make more power earlier.
If your engines exhaust gases cant get out due to a small turbine restricting flow its gunna lose power down low and produce less torque off boost when putting around on the streets off boost.
  • Like 1
2 hours ago, AngryRB said:
Gt3076 0.82 on my 30, plenty big enough, could even go down to 0.63 as still takes some revs to wake up.
Road use, the 3076 0.8A/R combination is damn hard to beat.  They pull down around 2000, and run up to 7000 without falling over.  They're not magical, but it's tried and proven.
If it's track, go to a 3576 0.8A/R.  Provided you're wearing blinkers and only want Garrett.  As per Piggy's comment, you need to let it breathe out.
  • Like 2
3 hours ago, Griffin said:
I'd imagine a .82 on 3576 would work much better.
Would be a good set up but if you're looking to make over the 400kW Mark I would seriously jam a bigger rear on.
Once I outgrow my turbo I may look along those lines however a GTX3576 with a 1.0x ish rear and twin scroll everything - blah blah blah lol
I'm not looking for 400+ out of this as it's just a stock low km bottom end. It's in a cefiro . About 350 would do
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
