On 24/11/2017 at 11:51 AM, ActionDan said:
Hah, Look at how many religious dudes voted no for SSM that love cock.
Why do you think someone's actual choices will line up with the opinion they push on others?
Fatz, will be a very good comparison - Looking forward to it.
Let's wait and see huh.
Buraz went between a 6262/0.84 PTE to a 9180/1.05 EFR which was tuned by Racepace. Said off boost it drove MUCH better, then belted it. A 6262/0.84 PTE to a 8374/1.05 EFR will be a walk in the park if it's tuned correctly. ?
Yea will find out
i like a bit of lag on say a mid to high third gear corner
car has a chance to settle before you try to rip the face of the rubber
bigger  rear end also allows a nicer roll onto power with limited wheel spin
test will be say turn 9 at ec if you can use third instead of second and go just as fast I'll be laughing
really the only reason I bought it was because pissbin was super impressed at high kuntry
This thread needs more speedhunters buzzwords.
How much attack are you aiming for?
Will you be getting sponsorship from Rotiform and air ride suspension?
This is a completely Street legal, daily driven, function + form build, yeah?
I love this build. Just filled with style and perfection. Very on-point.
  • Like 1
2 minutes ago, ActionDan said:
I've got so many left over stickers from purchases that never get used.
Just tell me what you want fam, Aeroflow? Moroso? Kelford Cams?
you're owning your silvia wrong, why the bolt on flares but not stickerbombed?? epic life fail
1 hour ago, fatz said:
Will also start my own world record like motive dvd
Fastest purple gtr with white rims, high mount and stock bottom end to never go to the drag strip
Good good, we all need specific records.
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
