  • 6 months later...
Minor update
Got Jenna a r32 gtr and slapped motor from my 33 into it added to4z and halaltech and about to gt it registered 335kw
also convert d r31 to turbo and has some fun
now it’s time for the 33 to get on the track
have sorted dry sump
fuel setup
and electric power steeirng
rear diff is off getting a few extra plate
hof 4:4 diffs
arc intercooler
few other bits
guve me 3 months and she will be ready to come off the hoist
5 hours ago, fatz said:
In Cabin  under passenger seat  ( cold side has fuel and power steering coolers and filters)
currently has -16 lines through there but was considering running alloy hard lines through the cabin
Isn't that a bit WH&S for a stance build....
It looks like it coming together quite well.
Need more random pics of unrelated stuff, with cool stuff in the background of course
And more dick stickers, everyone loves the dick
  • 1 month later...
On 11/28/2017 at 11:42 AM, niZmO_Man said:
Inspiration for you
It may just be me, but I freaked hate the camber look. I mean, you and can have a rough GTR and have straight wheels.
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
