  • 6 months later...
Minor update
Got Jenna a r32 gtr and slapped motor from my 33 into it added to4z and halaltech and about to gt it registered 335kw
also convert d r31 to turbo and has some fun
now it’s time for the 33 to get on the track
have sorted dry sump
fuel setup
and electric power steeirng
rear diff is off getting a few extra plate
hof 4:4 diffs
arc intercooler
few other bits
guve me 3 months and she will be ready to come off the hoist
5 hours ago, fatz said:
In Cabin  under passenger seat  ( cold side has fuel and power steering coolers and filters)
currently has -16 lines through there but was considering running alloy hard lines through the cabin
Isn't that a bit WH&S for a stance build....
It looks like it coming together quite well.
Need more random pics of unrelated stuff, with cool stuff in the background of course
And more dick stickers, everyone loves the dick
  • 1 month later...
On 11/28/2017 at 11:42 AM, niZmO_Man said:
Inspiration for you
It may just be me, but I freaked hate the camber look. I mean, you and can have a rough GTR and have straight wheels.
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
