  • Replies 71
I'm interested... Need to sort some funds out, but if the timing is right I'm definitely on the list to get some of these..
Hey Guys,
ive organised some sweet prices on a set of 6 x 540cc injectors which are straight fit into the rb25det fuel rail.
These injectors are high impedence, side feed and same size as stock, so no problems in fitting. They are manufactured by Hitachi Unisia Jecs(same manufacturer for Original injectors for many Subaru cars, STi, Nissan, Nismo, Apexi, HKS, Power enterprise..etc)
The clips are slightly different, and either can be modified quite easily ive been told to fit into our plugs, or we can purchase correct plugs from mitsu electric.
These are ultra atomization technology injectors that assure the very fine atomization of fuel, making your idle stable and providing impressive fuel efficiency.
The injectors flow:
470cc/min at 38psi (standard fuel pressure)
500cc/min at 45psi
540cc/min at 52psi
575cc/min at 60psi
What this means is that to get the correct cc out of them, you will also need an adjustable fuel pressure regulator, but I have been assured the injectors are designed to run this amount of pressure, so they will be fine.
Retail Price on these are $1060 for 6.
If i can organise 10 sets, then the price is $520 = postage ($10 approx?)
So comon guys, this is our chance of gettin injectors finally cheap. Excellent quality injectors made by the same companies as the more expensive ones.
The List of interested people:
EnricoPalazzo
Shane
JaFF
GIGOLO
bigcarl
rb25
Muz
Al
Beautiful timing, put me on the list as a definite (assuming, of course, that all technical stuff is easily resolvable. :cool: )
Only need one more and thats the ten. :P
Count me in.
This is a fine price for direct fitters.Enrico can you tell us if the plugs are a fit or not.
Enricopalazzo
Give me your email so i can contact you.
My email is [email protected]
Like i said im not closin the group buy til next month, + if we get more ill try get more off the price...
Im still waiting for info on the plugs guys.
Are there any other questions needed to be asked?
Enrico - You'll be able to easily answer this one for me. I have stock fuel system running on my R33.. When I want to install these and have them running at an optimum rate, will i need to get a fuel pump and upgrade my fuel rail, or just the case of installing a fuel regulator?
I've always been confused on this point... Otherwise sounds good.
The fuel injectors can flow 470cc at stock 38psi fuel pressure. U will not need to modify anything to fit them, however it is very unlikely that the stock Fuel pump can flow that much though. Therefore to get full usuage out of these injectos, u would need to purchase a bigger fuel pump aswell, so that it can flow enough fuel to the injectors
Hope that makes sense.
Enrico, I was looking at installing these myself and there are a couple of consumable parts that need to be replaced such as o rings and insulators when the old ones come off.
Would you know where I could get these from?
Are you going to have these parts installed or do it yourself?
PM sent
Trust33:
These injectors are brand new, and disigned to fit in the std RB25det fuel rail
ie: High impedance, side mounted.
NOTE: I do not believe that the std ecu (alone) can handle these injectors. You may need a "piggyback" unit or an aftermarket engine management.
Enrico:
Is your contact/supplier able to supply 700cc (or greater) LOW impedance, side mounted injectors?
Just that i am running a wolf 3d and low impedance injectors pulse quicker than high impedance, when idling. The wolf can easily controll both, i just prefer the advantages of the low impedance.
i will find out for u Al.
Im still waitin on the info about the clips and plugs.
Also Im not sure whether the stock ECU can handle these so its best u do ur own research. However if u were still using the Stock ECU id think there would be no need for aftermarket injectors.
Correctomundo!
People with stock ECU and even S-AFC should tread carefully.
It works but it won't work as good as people make it out to be.
Fully programmable ECU is what you need.
Once you go 550cc/AFM, it's time to think ECU.
T.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
