hey guys just got a question in regards to the water lines on a rb26 inlet manifold. basically running a rb26/30 with a oil cooled borgwarner turbo and need to know if i can just block off the factory water line barbs on the rb26 intake manifold. there run through a large tube on the manifold. and those two hoses run to the twin turbo's. if blocking off would these cause any issues to the cooling effect on the motor cheers guys
https://www.sau.com.au/forums/topic/472267-rb2630-water-lines/
