so basically im looking to build a 30de engine
 i want to go high comp na for whatever reasons that dont really matter at this point     haha 1 point left cant drive turbo blah blah blah all the usual shit
THE BLOCK what i want to build consists of a 30e block, crank and rods, 25de pistons shave the block 1mm to get the pistons up a bit because they sit 1mm further down the 30e pistons. THE HEAD this will be a det neo head with re lapped valves stock springs. either 250ish degree regrinds or 260 degree poncam drop ins with an adjustable exhaust cam gear and stock intake stuff to keep variable timing. im going to just skim the head this should bring the compression to somewhere around 12:1. im going to grub screw the oil gallerie in the block and run a head oil drain kit. im going to drill and tap an oil gallery in the side of the block to run a hard line up to the vct stuff pics below. and ill be porting the head myself a decent amount but i wont be going crazy.
i need advice on what i should do for the intake manifold. do i a lave the stock neo intake manifold on to get the engine in and work out any bugs. B use a neo freddy plenum. or C relocate the vct solenoid and go to rb26 itbs using an adapter plate and some ram tubes on the itbs of some sort. the other thing i need to know is exactly where to put the stud for the new tensioner for the timing belt and if it differs from the standard r33 25det head conversion..
my final goal is as close to 160kw as possible on e85 and im going to be revving it as high as it wants to make power. i was thinking cap the revs at 7500 cause i reckon it will drop off before then anyway.
anyone got any tips or advice on things i should change or shit i just completely overlooked. anything really cause this is all theory in my head based off other builds
https://www.sau.com.au/forums/topic/472283-rb30de-neo-engine-build-questions/
  • 4 weeks later...
If you're in Sydney I have the following items of which may benefit you:
  • RB25DET NEO Head Bolts/Washer
  • RB25DET NEO Intake/Exhaust Cam Shafts
  • RB25DET NEO Pistons and Rods
  • RB25DET NEO Injectors
  • RB25DET NEO OEM Head Gasket (brand new)
  • RB25DET NEO OEM Exhaust Manifold Gasket (brand new)
  • 3 months later...
Um, 3 litre twin cam 12:1 compression and E85, and you only want 160kW?  I assume that's at the wheels, but it's still a pretty low goal.  I mean, a stock 7M-GE was 142 kW (at the fly) way back in the 80s.  The 25DE Neo is 147kW at the fly.  You're only talking about 50 extra kW at the treads with an extra 20% displacement and cams and porting and alcohol.
I'd be aiming for the moon.  9000rpm, Weber pattern (or similar) ITBs in a fibreglass airbox (think Pipercross), 280+° and as much lift as can be squeezed into the head.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
