Will running the car without a PCV vavle and shoving a rag in the rocker cover and driving it on boost break the turbo?
As thread title suggests.
Took car to mechanic, got it back with entire PCV vavle and S shaped hose attached to it missing. Mechanic says "we broke that sorry, just stuff a rag in the hole to stop the smoke"
I did that and drove around like that for a few days. Turbo slowly "died"  after a day or two blowing smoke, no boost and farty whirry sound.
I thought It was a water line they didn't fit while flushing engine block etc that blew turbo but it seems it may have been the PCV?
No i did not take it back to them to demand I fix it. I haven't spoken to them for months. It did not even get a receipt since i have been using them for many years. I did not want to bother at the time but Only now i realized  shit could that have been the reason the turbo blew?
I glued it back together and it doesnt smoke anymore but I dont trust it better get a new one? It may block oil draining out of turbo due to excessive pressure in crank, correct?
Edited by sonicz
I put a cork in mine but then I also installed crankcase breathers.  Can you get replacements from a wrecker or some-one selling parts?
Yea I found a original one. Just in case it wasnt clear i was trying to find out why the orignal turbo blew up. the new turbo did not blow up.
Edited by sonicz
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
