speed beeper! how do I kill it?
the cefiro I bought had a speed beeper at over 100kms /hr.
sounds quite ghey.
can anyone tell me how to kill it? I assume I will need to disconnect the speed warning unit from the behind the dash right? Prob is I don't know what to look for.
I bet most of you have done this already so help out a noobi!
cheers cefironites
id say like most of them theyre located behind the dials in the dash... other than, see if you can find the fuse for it... anyone have a wiring diagram of a ceffy?
i had one on my gtr which funnily enough didn't start chiming til 160... go figure lol
hahahahaha "warning! warning! ur already way above the speed limits of any road... slow down before you hit the cars speed limiter!!!"
yeah it cracked me up, a friend was driving and gave it a squirt and just as she was backing off we here this chiming sound lol
"warning warning if caught please bend over"
classic.
so I guess no ones done this themselves then? hmmm. well I would like to hear what your mechanic says pimp, and how mucho deniro it cost you to get it removed!
what were they thinking, a turbo 6 with a beeper at a measly 100kms an hour....
random q, what is the max speed limit on jap freeways? 110??
All taxis in Singapore has it.... and those taxi drivers there just dun care they keep caining it on the freeway, ding dong ding dong all the way from airport to hotel.... I found it quite hillarious.
Talked to some car stereo guys and they reckon it's on the left hand side of the steering column (lhs from the drivers seat perspective) and its a plastic bit with a little circle and exclaimation mark (or similar) in it.
*shrugs*
I'll look this weekend and post if I have any luck.
omg omg omg!!!!
does it sound like wat the a86 in initial d has if so when u take it off can i have it to put on my r33 :)
your kidding right???
you want the little chime to be going every time your going over 105kmph? i take it you don't do much freeway driving then?
Does the speed beeper is in the same box as the reverse gear beeper?
My car still beeps when reversing, but when i go over 105 or 110 there was no ding dong sound so i guess the prev owner must have disabled it? or was it a part of compliance to remove it as it's not ADR?
Yeah, there are like 3 little boxes down under the kick pannel thing near your left knee, from memory its the 3rd one, across, the one most of the left. The one most on the right was the door open, and lights on beep, and we never worked out what the middle one was... but it wasnt it :rofl:
I found a nice way to get revenge on this item is throw it out the window at about 110kmh, and yell at it DING NOW!!!
Prob is now the diff annoys me more...
LOL this is so funny.... hahaha
in my case if i ever find that beeper thing i'd put it under my rear tyres, put my car into reverse and run over it.
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
