15 hours ago, pet vl said:
So i have a 25/30 with n1 pump and iam wanting to drop the pressure of the pump to like 60psi on full revs some one told me that thort you can take a spring out of the pump dose any one know
If you want to lower the pressure you need to replace the spring with another, softer one. I did this on mine but its a Tomei not a Nismo pump and it easy as it has an external adjustment.
Frankly I wouldn't bother.
I was going to get the tomie one but i wanted a spline drive gear set the it takes ages for the pressure to come down and only comes down to 85-90 takes over half an hour to come down i want to start racing it so with oil pressure at 130-140 +for the first half hour of driving its not an option any more
Yer its a n1 oil pump with spool spline drive gears its just how long it takes to come down running 140 plus oil pressure iam not so keen on my tuner thinks it has the potential to blow the filter of and with that much oil pressure fills the head
I dont really see a problem here. Cold oil is thicker so you will run higher pressure until it warms up. As far as I'm concerned, 60psi at full revs is far too low. Mine runs around the same oil pressure when its warm, im not sure why yours is so high when its cold.
Simple fix - dont rev it until its warm.
Im guessing you have an oil cooler? Does it have a thermostat in the system? Sounds like it doesnt. My oil gets up to temp after about 5-10 mins of light driving
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
