Hi, for sale is my 2002 V35 GT8 sedan 145,xxx kms registered to January 2018 $1,900.
VQ35DE 3.5l engine (200 kw), 8-speed CVT gearbox with paddles for shifting.
Pros   |   The body is in great condition, suspension good with recent updates  to the front upper and lower control arm bushes and front and rear sway bar links, interior is in good overall condition (though there are some tears on the driver's seat bolsters), CVT gearbox works really well and never had any troubles at all, tyres and brakes in fair condition, well maintained car. I've owned the car for ten years and am the first Australian owner with the car driven by my wife for about the first eight years.
Cons   |   F0 error on CD player (aux in cable works for phones/iPods), tears on the drivers seat bolsters, 10-cent coin size dent on the passenger-side front guard, diff has a bit of a whine, car has an issue managing temperature on long trips which is undiagnosed but may be related to a head gasket leak (described in more detail below).
Recently, the car's temperature has become erratic on trips greater than 40km (sometimes longer >50km and sometimes less ~35km). The car runs normally / good with-out any issues at lower distances. On occasions the temperature will rise and fall with-out the need to stop. On other occasions I've chosen to stop for <5 minutes (to avoid running up too much temperature) after which it sometimes will run again with-out a problem; on other occasions I've chosen to stop a few times (it's 51km from home to work). The issue is undiagnosed; these symptoms are described in the workshop manual as potentially an exhaust leak in one of the head gaskets. Note though that there is no mixing of the coolant and oil.
As mentioned, the car can be driven shorter distances with no troubles and is available for test drives.
The car is located in Elderslie NSW. I can be contacted by PM or phone on 0435 844 866.
https://www.sau.com.au/forums/topic/472332-v35-gt8-sedan-sydney-cheap/
Your heat issue could be the electronic fan dicking around - it's ECU controlled and if not working these cars overheat very easily / do head gaskets. Common issue...
  • 5 months later...
I know wrote this along time ago but gt-8s aren't electronic fans. They are old school clutch fans which are more efficient
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
