Hi guys,
I took my R33 to be tuned. The Tuner didn't end up tuning to a suspect headgasket leak after overheating.
He said it pressurised the overflow bottle with coolant and has a constant stream of bubbles when trying to bleed the cooling system.
I tried to bleed the cooling system myself and there are some bubbles after 500km of driving it so no air should be present especially after a fair few heat cycles. But not a constant stream maybe a couple bubbles every minute or so.
Does this sound like blown headgasket?
If so, can I get away with resurfacing the head, putting a MLS headgasket on and ARP headstuds?
Can anyone confirm if you can take head off without taking cams out and reinstall it with cams in and fit the arp head bolts in?
Can someone link me to an engine manual I can either buy or download?
Much appreciated, can't wait to get car back on road.
Thank you.
Id be using a stock headgasket as they have more tolerance to the mating surfaces..
Yeah 100% agree with this. There are usually pretty specific roughness ratings required for a good seal on an MLS.
Dont just assume that MLS are always better. Std gasket will be fine by the sounds of what you are after. If you build an engine from the ground up, thats the time to think about MLS.
ARP head studs are a better idea.
I agree with this, however the tuner recommended a MLS headgasket and has already placed the order so I am stuck with going with it now.
Ended up pulling the head off, did have a minor leak in the gasket incase anyone reading this in the future. Horrible job to get the head off not fun at all.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
