Having some dramas, my partner's S1 RS4V lost its brake lights yesterday. High mount, sides and centre all dead. Park/Tail/reverse lights fine.
Stuff I've checked:
-There's no voltage at the pedal switch
-Brake light fuse intact, swapped with spare, no change, measured no voltage at fuse.
-Globes fine.
I'm tearing my remaining hair out, and I have about 24 hours in which to get it sorted.
The ATTESA pump is also priming abnormally long and intermittently chucking the 4WD light. Both things have happened inside a couple of days so I feel there may be a connection.
Solved issue.
Someone had tapped the 12v feed and it had partly fried, this in turn caused the pedal switch to fail. Ran new wires and replaced switch.
Worth checking. I have a D21, had a look at it, someone had tapped the same wire on it for some long removed device, aaaaand the same on my HR31! Luckily they'd been done a bit better.
