Hi all
i have a stock rb25 neo for road use. I'm considering my turbo options, current spec is gtr 570cc injectors, hks 2530, power fc, intercooler and the usual bolt on stuff
ive had plenty of skylines and silvias but never had anything top mounted so I think it's time
i have not got massive power figures on my agenda, but response and solid boost while not pushing the neo to hard. I've narrowed it to the gen2 5558 precision or the gtx3076 gen2, any opinions ?
i will either use 6 boost, sinco or a CRG manifold, v band likely
and need advice on a wastegate too, is 40mm enough? It will run 98ron and
I have a r35 gtr afm which I hope will cope ?
thanks
I have a 7670 and personally reckon it's a big big for a stock 25. I have a 2.8 and wished it was a little more repsonsive, I don't think i'd be happy with it myself on a 2.5.
My vote is for a GTX3071, but if you demand specific power and only have access to 98, you may need to have some lag to get there.
  • Like 1
I'd be looking at your setup, there is an issue somewhere. Your 7670 is "coming on" at the same time as my 8374 and I don't have VCT. (All on at 3500 rpm rolling it on in second).
A 7670 would be epic on a RB25.
  • Like 1
R35 AFM might tap out unless you run it in a larger pipe say 3.5" or run it on the cold side before the TB.
I did a S15 running a R35 AFM, although in a 3" pipe without any air straighteners installed and it was hitting 4.8V each time it came on boost for a car only making ~240kW.
I prefer the HPX version of the R35 card as it supports more air flow in the same pipe.
@bri73y runs an EFR7670 on an R33 GTS25t (still RB25) on 98 and from all I can tell he is pretty happy with it's performance, he shared this dyno plot (EFR7670 vs HTA3076 on pump gas) showing the 7670 making near 370rwkw and 200kw by 4000rpm
  • Like 4
Mr Lith could you pass on the final results of that RB25 you knew of with the EFR 7064 , think it was T3 IWG on the standard exhaust manifold .
Sounded like it was really strong for something with number plates , and not exactly lacking round town .
I reckon this would be really nice on a street Neo powered Skyline .
We still haven't had a good dyno session with it thanks to boost control and ignition issues - I think we hit around 280kw @ hubs before ignition break down stopped our last session, however we've got it holding around 21psi on the road now and no misfire so hopefully when we next get on the dyno all will be well.
It builds boost VERY similarly to an HKS GT2535, but with the EFR "transient response" and more turbine flow - so more power per psi, it's pretty good for a >50lb/min turbo.
Edited by Lithium
  • 4 weeks later...
https://www.sau.com.au/forums/topic/472431-r32-gtr-efr-7670-build/
Check this thread above^^, and read in conjunction with Lithium's comments in this thread to your question.
IMO the short answer is "no".  You don't "need" split pulse to achieve your performance targets.  But if you have the budget, yes you should consider it - but stay IWG for the relative simplicity of install.
There's enough accumulated experience that suggests a properly executed EWG setup will be a performance improvement on an IWG.  Comment applies to single scroll and twin scroll.
I wouldn't discount the idea of a well designed manifold/gate setup, and a reasonably high spec single scroll turbo.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
    • This is what I've done, add DC until it meets my fuel pressure requirements and above 4500 at over 1bar of boost, I send its mum with 100% DC to both pumps. I'll post up a table soon when I'm free.
