Greetings from Baltimore, Maryland, USA.
Just took delivery of my GTR this past weekend after waiting over 10 years to buy one. Every time I ever searched anything related to Skylines, this site would always help answer my questions. Figured now would be a good time to join.
The car is mint. 54,000 kms when I got her. Perfect original black paint, LMGT4 wheels, Ohlins coilovers, Nismo control arms, R33 Brembos all around, Mine's intakes, 4" cat back exhaust, Nismo side skirts, East Bear front bumper...Very excited to be part of the community.
DJ
  • Like 2
https://www.sau.com.au/forums/topic/472403-new-r32-gtr-owner-usa/
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
