High Beam Screw adjusters - BNR32
omnigear
 Share
just to make sure you know, you have to replace both the gears, the one in the adjuster and on the headlight, looks like they are aluminium so they will last forever mate
you can buy the Tamiya SP-602 set from just about any hobby shop or on ebay for a few dollars, you just have to make them fit and line up nice, i hope this helps you mate
yep i sure am, i hope all members are like this, i really hope this helps the op out, looks like people have been doing this to there cars with the same type adjuster for years and since the gears are aluminium it should last forever
  • Like 1
the pdf file has a easy step by step showing how to easily replace them, but if you dont feel comfortable then you shouldnt attempt it i guess, but it does look very simple
thats awesome mate, so did you order the tamiya sp-602 gear set from ebay or somewhere? I believe the actual order number from tamiya is 50602. but i seen them on ebay cheap anyways, so is this what your definatly going to do, in my opinion it is the best option cos the metal gears will last forever, but i did get a msg from a member here called firstgtst and he said he has an old headlight, he replied to a thread i put up on the wanted section asking if anyone had an old broken r32 headlight, i just sent him a msg asking him to check if the adjusters gears are good and asked how much he wants for it, i will let you know what he says, but i would seriously go for the metal gears anyways cos you never know how good secondhand adjusters are and how long they will last you
good stuff mate let me know how you go installing them and if it is as easy as it looks and works perfectly once its done, at least you will know the cogs will last forever
  • 1 year later...
Thread bump, there is a part number for the adjuster part that mounts to the headlight
26022-40P01
You're welcome ;)
Edited by feartherb26
  • Like 1
 Share
