I have ordered new o2 sensor and coolant sensor, I get terrine fuel economy and a miss I'm idle so it's on its way out, and have ordered coolant temp sensor. I don't know for sure it's but the car never gets to operating temp on the dash dial. It sits a 8 o'clock sorta angle. What I read was that the coolant temp sensor can cause the huge regarding of the vct and running rich because it thinks the engine may be over hearing as sorta protective mode. I had intermittent check engine light when engine would ping hasn't pinged since new coil packs however. So from what I hear it is pre ignition will update once I install the new sensors holding for the best
  • 9 months later...
Hey, sorry to bump an old topic but I didn't want to create a new one as this is very similar to the issue i'm having.
Curious if your repairs sorted out your issue? I've replaced coils, plugs, soldered the MAF and fixed a vacuum leak but my car still doesnt like revving past 5k once its hot. Doesnt matter what gear, can even be neutral. Just breaks up like crazy :(
It reaches full boost well below 4k(got the restrictor bypassed) and holds fine until 5k. It also does it even if i just use partial throttle, so I dont think fuel or boost leak is the issue. Its running the stock original fuel pump but I can smell lots of fuel when It does it in neutral.
i'm wondering if my MAF just isnt any good. Or for some reason its not getting sufficient spark. I'll have to re-check my plugs and maybe swap a known good MAF. It just started all of a sudden. It ran mint up until a few weeks ago.
Edit: i'll check out the ECT sensor. My gauge reads fine and dandy as always but ya never know!
Edited by Ryno34
  • 2 months later...
It seems fine in all weather until it gets to operating temp. Even once warm it still idles and drives fine. It’s just when I try to put any power down above 4k rpm it sputters and pops like crazy. It’s frustrating not being able to use the fun half of the rev range haha
Edit: It also does it if I bring the revs up slowly, and does it in neutral. Boost is good until 4k. Then it obviously starts dropping as the engine starts to misfire.
I tried pushing to redline the one time and it just wouldnt make it past 5500. The cloud of smoke behind the car was rediculous haha so its getting fuel. It holds max boost until it starts to misfire so I can only assume its not a boost issue(maybe i’m wrong?).
i dunno. Cars....
Edited by Ryno34
That sounds just like the problem i am javing mate.  Mine runs prefect when cold and as soon as it gets to op temp the boost wont kick in till about 3k rpm and then after 4k rpm it pops and cuts in and out.
I have tried new spitfire coils and plugs gapped to 0.8mm, manual boost controller and redoing vac lines and its still doing it
Could be fuel related. But it seems odd that it would be fine (did a 7krpm pull) without issue when it was just below its normal operating temp on the gauge(I know, I know, just wanted to test).
i also find if I sit in traffic for a while on a hot day, the rpm at which it starts acting up drops significantly. Like the one day I was in stop and go and it was doing it at around 3000rpm.  Almost like something is getting heaksoaked. It feels like weak soark/coils but i’ve tried two sets of coils and plugs lol
  • 5 months later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
