4 hours ago, fatz said:
Should also say in America where all the epic numbers come from their ponies are smaller than the rest of the world so this may also lead to disappointment cause it didn't make 400kw
The fat man is correct.
Here is 1 American hp
  • Like 5
  • 3 months later...
36 minutes ago, MattSR said:
What brand of trigger disc is that?
This particular one is just made here locally in NZ - just as a cheaper alternative to the ross ones you usually see. CNC'd disc and a bosch sensor. $380.
  • 5 weeks later...
1 hour ago, Komdotkom said:
Any news on this? I'm keen to hear if you have managed to pick up any hidden hp with the altered trigger.
I'm still hoping that there's a way to get the IWG EFR's to make decent numbers.
Car is just about to be painted following on from some rust repairs, will be tuned on E85 after I get a bigger fuel pump in there. I should have something within the month provided the tuner is available.
The IWG didn't cause any problems for me apart from the actuator bolts on the arm coming loose.. the boost control was fine there. Will likely be getting a harder spring too before the tune. Will be good to see what happens when we can add more timing down low and see how aggressive it can really come on!
Sorry for the lack of updates!
  • Like 2
  • 8 months later...
Updated results, still 98octane with the updated cam trigger.
Skinny red trace: Old tune low boost
Skinny green trace: Old tune high boost
Solid green trace: New tune low boost (10.5psi)
Solid red trace: New tune high boost (21.5psi)
ECU onboard MAP sensor is limiting boost.
Edited by Dievos
  • Like 4
So that means? Am I guessing right that 75% of the improvement is fuel as E85 masks the high back pressure and any inefficiency in the setup and just gets busy making numbers? Then may the tune with more accurate ignition?
I know my old setup loved going to E85 as it simply allowed more boost and ignition everywhere over 98 when the thing just became too prone to detonation. E85 seems to make inefficient air pumps work a load better.
Looks a far better result and imagine drives like a different beast
What it means is that the car does not have any issues continuing to make more power at high rpm - this set up made as much as 368kwatw with power actually wanting to increase but was out of the knock threshold for 98 and we couldn't try more boost as the ECU MAP sensor was maxed. Boost control does not spike when it reaches full boost and the control tables are still quite basic.
Edited by Dievos
  • Like 1
So more accurate ignition control paid huge dividends.  That's great news.
98 fuel is the current limiting factor, and to run more boost you will need to pull timing to keep it together?
Mid range torque looks like it should pull hard off corners with awd traction capability.  Very good - must be very satisfying to drive.
Wonder why torque drops so noticeably around 62-6400?  Very similar trait to RB25. Be interesting to see what EMAP looks like
On 12/16/2018 at 10:31 AM, fatz said:
this Australia or nz cause that’s mythical power on 98?
Power sounds right, it's on a hub dyno. Put some wheels on it and drop it onto a Mainline and probably read about 15 to 20kW less.
Put it onto a Dyno Dynamics and it will read more power (especially if the ambient temp sensor is disconnected or left near a heat source lol).
  • 8 months later...
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
