i have an r33 gtst and just had timing belt and a new exhaust manifold put on cos the old one cracked in half, the mechanic said my lifters are noisy so that must be the wining noise when im driving, anyways i know my oil needs changing so i wana put something thicker in to quiet it down a bit cos its loud at idle, would a 10w40 do it or what would you recommend
https://www.sau.com.au/forums/topic/472436-oil-to-help-quieten-engine/
yeah sorry i didnt explain it all properly, the engine has a loud tick when its idling, very loud and i suspect that the oil is stuffed cos i havnt changed it in years, i just keep topping it up instead so i think that might be contributing to the noisy lifters so i want to get an oil thats maybe a little thicker so it will quiet down lifter noise so that why i was asking if 10w40 is a good idea.
so if anyone has any suggestions on what weight of oil i should go for a car that has 180,000k on the clock and has noisy lifters.
Secondly im not sure if this other noise is from the lifters but it seems that when im driving the car it seems to whine, almost like those kids toy cars that you push a few times to wind them up and them let them go, it gets louder and faster with rpm. I just thought it was cos if the lifters cos the car is going faster so that knocking/tapping noise gets faster and turns into that noise i get, but now im not so sure. I just had the timing belt done by a mechanic and he probably just used a standard one, the noise was happening before the belt change and i could even hear it over the noise of my broken exhaust manifold, more of a winding noise than a whining noise. i will have to check to make sure its not from the alternator and i read that a power steering pump can make a whining noise but i dont know if its the same type of noise im getting.
could i take the power steering belt off and take it for a drive to check if the noise is still there or gone??
anyways guys sorry for the long post, but i really need to go get oil in the morning cos it needs changing bad so does anyone have ideas on what weight to get??
I would use an engine flush then use a 10w-40 oil, i prefer 0w-40Mobil 1 but whatever. Maybe in your case i would do a oil change with some cheaper oil and then repeat flush and oil change after 2000kms to help flush the crap out.
Then id disconnect all auxillary belts for a few brief start ups to help figure out the whining source.  But from my own experience the OEM timing belt does have a slight whine to it, and hopefully you did the water pump and idle/tensioner bearings with the new belt and its all correctly tensioned.
Edited by AngryRB
Any new oil is going to be better than the oil in your motor at the moment. Even a shitty bottle of 10W40 Magnetec will be better.
yes thankyou thats exactly what i done, i used the nulon engine oil flush and ran it for 20mims them dumped the oil and put a new filter on it and put some cheap 10w40 semi synthetic in it cos i will dump it in a week or so and then put another new filter and some good full synthetic in it and then it will be good then.
When i put the oil in and started the car i wasnt too happy cos it was still ticking/hammering pretty loud, i drove my misses into town to work and back and it was still loud, so i decided to go for a better drive and give it a bit of a punch and by the time i got back the noise had gone and sounds luke a brand new bloody car!!
I recommend anyone who has the dredded lifter ticking/hammering to do this, it worked for me and i couldnt be happier and i know the engine is much much happier as well
and i should also mention that when i say i gave it a bit of a punch i dont mean i broke the speed limit or anything, i just more got it from 0 to 110 quickly a few times. i would not recommend speeding especially when your taking the car for a drive cos the lifters are very loud, cos if they are stuffed it could cause a major engine failure i would assume.
Nothing wrong with the cheap semi synth oil, full synthetics advantage is longer change intervals. Oil tech has improved since our cars were new, so there is no penalty in using the cheaper stuff. I'm of the opinion that cheaper oil changed more frequently is an advantage because it removes more sludge from the engine. For turbo engines I change the oil every 6 months or 5 000Km, which ever comes first.
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
    • Barrels don't need to be shiny clean. But they are certainly nicer when they are not polluted with years of brake dust, and worse the rotting corpses of the last 17 balance weight sticky pads scattered all around.
    • Yeah, type a special character like ^ or | to initiate the equivalent of the "at"ing for thread links. Although, it might not get any easier to manage. Imagine 30 or 40 threads that kinda match what you want, and the one you want is lost after a long list of useless ones. The magic keyword version I proposed would be a manual effort to set up each case. More of a directed effort from the greybeards to facilitate exposure of useful content. I'm not against the auto complete stuff being considered - maybe por que no los dos? (And where I said "triggered automatically" in my OP, I meant "triggered accidentally". Of course I want it to be automatic!!)
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
