My gearbox developed a whining sound in all gears. (louder under load)
I changed the oil and there were metal shavings at the magnet. (more than what you'd expect to see )
After the oil change the whining noise almost halved and is barley noticeable.
Shifting is smooth.
I suspect either the counter shaft or input shaft bearings, is that a common thing with these transmissions?
Any other usual suspects?
The box has about 70K on the odo, has never been abused except for the occasional drag run.
Power wise the engine makes about 290ish rkw
Cheers
Attached the picture of what the magnet caught.
Edited by Torques
added picture
Ok, the car has likely done double that distance and the previous owner/s may not have been so kind on the gearbox. The rb25det gearbox are well built with lack of maintenance and poor driving being a culprit for premature damage. Poor rebuilds are also a factor.
The car's odo is genuine.
I bought it at 63K 6 years ago as the first owner.
I got the Japanese factory logbook, exporter certificates and so forth.
Though paperwork can be falsified the physical appearance support that.
Headlights and windscreen are in mint condition , so is the interior (pedals, fabrics, etc)
Car looks mint from below as well ..
You don't have that with higher mileage cars.
I doubt the gearbox was ever touched, but of course you never know.
Edited by Torques
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
