Help my R34 GTT is suffering pretty bad Bump steer/Floating at high speed (100 k's)
I recently changed my right rear wheel bearing thinking it was my problem but the issue persists.
Example. Around 80 km/hr car feels fine. But when I get on the monash and reach 100 k's /hr if I hit any sort of bump pot hole the rear end floats to the side for a second and seems to mainly favour the rear floating to the left. It really don't feel good.
Can anyone tell me
What's going on??
The suspension only has very slightly lower springs otherwise all else is standard.
All help is much appreciated.
Thanks guys
Ash
9 hours ago, R31/4 GTT/S said:
In saying that the rear wheels are wearing out slightly more on the inside than the rest of The tyre.
This is a reasonable sign that your rear toe is not in control and does point to HICAS joints.  But that's only so long as you don't have excessive camber at the rear.
Many install a HICAS lock bar, but if your ends are worn you may need to replace them 1st (I did mine 10 years ago and don't remember how it all went together)
Having a computer decide where to point the rear wheels isn't great IMO
HICAS is short for the computer saying "Help I Can't Actually Steer"
Mike
  • Like 1
How much lower is the ride height?  Post up a pic of the car.
And confirming no aftermarket suspension arms in the rear?
HICAS is still fitted, or removed?
I'll try get a pic of the ride hight up. But it's not that much lower than other standard 34's.
Im assuming this caused the pre mature wear on my wheel bearing which was completely destroyed when I pulled the hub apart.
Does anyone know a part number for the hicas bits that I would need to change?
cheers
ash
Sorry for the Heap of Pics people.
But the first one shows the ride hight.
The second/third one shows where the hicas meets the hub.
Can Anyone please see where I have the problem.
It's driving my crazy. Driving at 100kl/hr and
Suddenly hit a bump. MORE on the left the car steers off and it's frieking scary.
PLEASE HELP
Jack up the rear end, so the wheels are off the ground. Hold one rear wheel at the 3 & 9 o'clock positions, and try and move it. If there is free play (ie you can make the wheel "steer"), get someone to move the wheel while you look & feel for where the play is. It is likely in the outer ball joints (where the Hicas tie-rods / steering arms join the wheel hub), but may also be in the inner tie-rod end - the joint inside the rubber boot where the tie-rods come out of the Hicas rack.
I've just fixed this on my R33 by replacing the Hicas lock bar & tie-rods / ball joints with a Hicas eliminator kit. You have the Hicas rack rather than the lock bar, but the same tie-rods & ball joints.
Old Hicas lock bar with tie-rods
The remains of the old ball joints
Eliminator kit installed
Edited by GeeDog
  • Like 2
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
