Help my R34 GTT is suffering pretty bad Bump steer/Floating at high speed (100 k's)
I recently changed my right rear wheel bearing thinking it was my problem but the issue persists.
Example. Around 80 km/hr car feels fine. But when I get on the monash and reach 100 k's /hr if I hit any sort of bump pot hole the rear end floats to the side for a second and seems to mainly favour the rear floating to the left. It really don't feel good.
Can anyone tell me
What's going on??
The suspension only has very slightly lower springs otherwise all else is standard.
All help is much appreciated.
Thanks guys
Ash
9 hours ago, R31/4 GTT/S said:
In saying that the rear wheels are wearing out slightly more on the inside than the rest of The tyre.
This is a reasonable sign that your rear toe is not in control and does point to HICAS joints.  But that's only so long as you don't have excessive camber at the rear.
Many install a HICAS lock bar, but if your ends are worn you may need to replace them 1st (I did mine 10 years ago and don't remember how it all went together)
Having a computer decide where to point the rear wheels isn't great IMO
HICAS is short for the computer saying "Help I Can't Actually Steer"
Mike
  • Like 1
How much lower is the ride height?  Post up a pic of the car.
And confirming no aftermarket suspension arms in the rear?
HICAS is still fitted, or removed?
I'll try get a pic of the ride hight up. But it's not that much lower than other standard 34's.
Im assuming this caused the pre mature wear on my wheel bearing which was completely destroyed when I pulled the hub apart.
Does anyone know a part number for the hicas bits that I would need to change?
cheers
ash
Sorry for the Heap of Pics people.
But the first one shows the ride hight.
The second/third one shows where the hicas meets the hub.
Can Anyone please see where I have the problem.
It's driving my crazy. Driving at 100kl/hr and
Suddenly hit a bump. MORE on the left the car steers off and it's frieking scary.
PLEASE HELP
Jack up the rear end, so the wheels are off the ground. Hold one rear wheel at the 3 & 9 o'clock positions, and try and move it. If there is free play (ie you can make the wheel "steer"), get someone to move the wheel while you look & feel for where the play is. It is likely in the outer ball joints (where the Hicas tie-rods / steering arms join the wheel hub), but may also be in the inner tie-rod end - the joint inside the rubber boot where the tie-rods come out of the Hicas rack.
I've just fixed this on my R33 by replacing the Hicas lock bar & tie-rods / ball joints with a Hicas eliminator kit. You have the Hicas rack rather than the lock bar, but the same tie-rods & ball joints.
Old Hicas lock bar with tie-rods
The remains of the old ball joints
Eliminator kit installed
Edited by GeeDog
  • Like 2
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
