Hi my r34 gtr always run lower oil temp since i import it 2 years ago. and now even lower with some addition mods like nismo thermostat, and big oil sump etc.
At moment it run max 75C(normally around 60c-70c depend outside temp) oil and 70C water on street. if i push it hard for 10 mins the oil temp still around 90c, water temp below 80c.
the car has nitto oil pump, high octane 9L sump, nismo oil cooler.  arc intercooler, nismo radiator. car is running e85 made near 500awkw.
should i worry about the oil temp?  i'm start thinking i got bad sensor:(
If you're running 10-40/50 synth oil, perfect operating temp is around 90 deg as far as i'm aware.
I'm running a Tridon 71 deg thermo i think. Sits on 80-83 deg in normal traffic and cruising.
You can tune around the lower temp using fuel/temp corrections, but 70-75 seems a bit too cold for these engines????
i'm not really worry about the water temp, but the oil temp look too low for me. the oil temp only go up to 80C+ when in really bad traffic like 10 mins drive 1km. i use 10w40 or 5w40 oil. maybe i should change to 5w30?
21 hours ago, GTSBoy said:
Oil and water in contact in the HX.  Warmer water = warmer oil too.
yes true. but even before i put the nismo thermostat the oil temp still that low.  with the nismo thermostat only the water temp goes lower which is normal for low temp thermostat.  i did a short drive today, found the oil temp did go up to 75c in city with a lot stops. water temp is around 70c if i cruising around , but it go up to 85c when stuck in traffic.
Get rid of the Nismo thermostat and replace with stock. Get a thermostat for your oil cooler and/or make a cover for the oil cooler when you are not thrashing the car. (maybe you are not pushing it hard enough!).
You are right. I did not pushing it hard enough:) but Is there any long term effect from the lower temp? The car drive perfectly. Power always there.   And I change oil every 3000kms or sooner.
I think Nismo oil cooler should include the oil thermostat plate?
3 hours ago, GTSBoy said:
Yes, running engines too cold increases wear, and fuel consumption (assuming tune is not adjusted to suit).
thanks for reply.  i will try use some cardboard block the oil cooler and see the different. my tune is suit for low temp no problem.
I recently installed oil cooler and gauges in my car.  I actually didn't think too much about the oil temp being too cold.
My gauge starts at 50.  I warm it up, then baby it, revving to 2500 until the gauge starts to move, but it never really gets more than 60 driving.  Running it hard through the hills it might maybe go to 70 and on the racetrack will go to 70-80 max.
I am running 15-60w penrite/nulon.  Should i be concerned or do anything ? The cardboard idea was good...
Greddy oil cooler located drivers side
It's not the 10 in 10-40 that you should consider changing down.  It's the 40.  The smaller number is the "winter" viscosity, which essentially how it behaves dead cold.  At 70 ish degrees, you're not talking about that end of the oil's rating, your talking about the normal end.  So if you're running 40 now, then 30 would be the logical decrease, if you were going to try to deal with your possible low-oil-temperature-causing-high-viscosity problem by running thinner oil, that is.
  • Like 1
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
