E85 swap
Griffin
 Share
Is there any benefit in switching from caltex eflex to United e85.
I understand the e85 has a higher ethanol content than eflex.
Will there be much of a gain after a return on United e85.
The reason on changing is more an availability issue.
Still sell it in NSW. And what GTSBoy said is correct, anything over 50% ethanol you already have most of the benefits of E85. If you question is "is the performance benefit worth driving an extra 30 mins to get united over caltex ethanol" then the answer is no. Might be 5-10kw and a tiny bit of knock resistance at best
22 minutes ago, Griffin said:
I had to fill up with United. It doesn't seem to run as good as eflex. Not as crisp throughout the rev range.
tune related, what are your AFRs like?
I suspect it is too lean now, do you have a wideband? log it... a simple, albeit lazy way to correct this is to reduce the size of your injectors in the ECU so it sprays more. Lazy mathematics say you would need to decrease your injector size by 7% (given the lazy way to go from 98RON to E85 is to reduce the injector size by 30%)
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
