I agree about the 30/35 size , but as I've said in the past I'd like to see a G28 as well because gut feeling is that a smidge more turbine than the G25 with a couple of compressor options is probably going to cover much of the hot roady needs .
If Garrett really does want volume sales they really need T3 and T4 turbine housings because for many 3" V band isn't an option . I'd like to see a G28 or G30 become the modern GT3076R T3 Integral Wastegate replacement .
A .
Edited by discopotato03
  • 5 weeks later...
The new G30 and G35 series are going to be released soon - their turbines being pretty much the same in size to the GT30 and GT35 turbines respectively, but much higher flowing.
Expect to see things along these lines:
G30-660 - basically the G25-660 compressor on a G30 turbine
G30-770 - 58mm inducer, 71mm exducer with ~69lb/min flow
G30-900 - 62mm inducer, 76mm exducer with ~81lb/min flow
G35-900 - Same as above but on a G35 turbine
G35-1050 - 68mm inducer, 84mm exducer with ~95lb/min flow
Should mix things up a bit!
  • Like 2
I think the G30-770 (or G3071) could prove to be the perfect point for Skylines/GT-Rs which people are going for solid power with but don't quite want to go to the point of big transmission upgrades etc etc - it fills a gap which I've felt has been left empty by the high end turbo manufacturers for some time, basically offering the kind of power that people used to (or sometimes still) use GT3582Rs or GT2860R-5s to reach but I would hope with WAY better response.
When soon is, I have no idea - they aren't officially released yet, I usually try and share interesting news no matter how little (though I thought sizes and flow rates isn't THAT light) in asap as people would appreciate it being shared but apparently that's not enough so I'll just leave it from now, I guess folks at least have an idea of whats coming and that it can't be TOO far away.
Edited by Lithium
33 minutes ago, Mick_o said:
I have talked a customer into going a G30 770 when it comes out. He was about to pull the trigger on a 3576. It Will be going on a 2.3L Mivec 4G63. Should be a pretty chunky thing...
That would be really interesting!!!  On paper it should be better all around, which would be nice :)
11 minutes ago, Butters said:
G35-1050  vs GT35 on spool will be interesting, can it match is and make 200 hp more ?
I would put money on the G35-1050 (I'll call it G3584 because it makes more sense to me) being significantly laggier.  These turbos should be compared on flow, not size.
G3071 fits between a GTX3576R and GTX3582R in flow, or slightly more than an original GT3582R.
G3076 is roughly equivalent to a GTX3582R Gen2 in flow, or more intriguing for some, it looks like the G3076 could be quite a similar match to an EFR9174, and the G3576 quite similar to an EFR9180 - but with MUCH smaller wheels.
G3584 is drifting into the territory of a GTX4294R in flow.
If you compared any of those G-series turbos with the previous Garrett equivalents flow wise then I suspect they will be much more responsive, however if you compared wheel size wise then they will behave like bigger turbos - both laggier, but also making WAY more power... just the balance of power and response will be better.
Edited by Lithium
Sweet! That is some AWESOME info Lith. It looks like you got a bit upset with me asking when soon was, I meant no offence or intended to sound ungrateful. Will digest this tomorrow in more detail, But I have to say the 1050 looks ridiculously efficient at 3:1pr at high flows. It's still at 70% at full speed, With an amazingly low surge margin to match. If it's an 68/84 compressor it's got the EFR 8474 spanked, and is frankly incredible they managed to get 78% out of it at that wheel trim.
I'm impressed.
Edited by burn4005
NW.
On this topic, just to clarify - I am making an assumption that they must be coming soon given there are compressor maps and other bits of info leaking out... I have no direct feed myself, I just keep ears and eyes open and people flick me things when they see it as I am clearly interested in this kind of thing - then I share what I find.   There is no official announcement from Garrett at this stage so I wouldn't hold breath on how soon "soon" is until they actually say anything.   It still could be a wee while away.
3 hours ago, discopotato03 said:
Likely to be hard pressed to find much for a while - but I back the stuff I have posted to prove to be pretty on point once things show up, so should give a reasonable idea.
Now that it seems more won't be shared immediately, I'll add that the G30 had .61 and .83 vband exhaust housings as options and the G35 has the same range of options as the GTX3584RS, but flows a bit more for each a/r.
4 hours ago, discopotato03 said:
I'm really interested to see how the G30-660 will go on 2-2.5L 4s and 6s .
I actually am more interested in seeing how the G25-660 goes, considering the .92a/r housing out flows most T3 options people use on RB25s as is.  It could be a banger of a thing.
  • Like 2
To yoink from another thread, the compressor map for the G30-770.   This is the one from the range I have been REALLY looking forward to, at a glance the compressor flow is sufficient to compete with the likes of an EFR8374 but from a turbo whose wheel sizes are probably closest to the likes of an EFR7163.  This thing on a typical street/track spec RB could prove to be absolutely awesome.
  • Thanks 1
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
