Hi all,
So basically my Series 1 C34 stag was stolen and I was lucky enough to get it back!
When I got it back I noticed my Xanavi system won't turn on at all BUT my climate control is working and seems to be permanently stuck on auto (my xanavi system houses my climate control so there's no way to turn it off without getting the xanavi to turn on).
Before I go spend some cash on an auto elec to diagnose/ fix, just wondering if anyone's had this issue before or would have an idea of what my problem could be so I could have a more educated look myself?
Would the thief unplug something when stealing the car?
unlucky timing with fuses?
Extra info;
Cigarette/ 12v power still works
my gearshift lights (P R N D 2 1) turn on from time to time but very occasional - worked perfectly before
the light for my "power/ snow" switch still works when in power mode
when I got it back my centre console was popped open (assuming it was done when stealing)
Any help would be appreciated,
Cheers, Nick.
https://www.sau.com.au/forums/topic/472559-c34-xanavi-problems-help/
AS I mentioned on the facebook page, the Xanavi units are known for failing. Usually it is the internal power control unit or dry joints that have happened over time. The units run very hot and the cooling system in them is not adequate for the heat generated.
Does the unit beep when you power on?
    • Yes, I know馃檮 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole馃ぃ
    • You鈥檒l be very upset when you bust that too not to mention the gearing totally sucks. Don鈥檛 do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30掳 silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30掳 silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
