Hey guys,
Just a heads up - we have a FEW spots left for our Winton day. This time we're not letting anyone else co host the event (We had some issues in the past with other clubs not being able to run events to our standards) and will be doing it on our own as per usual.
If anyone came last year we had a fantastic turnout and fantastic event, cars got amazing amounts of track time etc
$195 entry for the day.
First 30 newbies/L1/come and try entrants will get a FREE upgrade from a L1 day license to a YEARLY Level 2 Speed license! (10-15 gone so far)
Less than 10 spots left!
https://www.facebook.com/events/228418254329884/
P.S You DONT need to be a Uni student (name is more of a tradition thing for our November track event) if SAU gets 5 or more people we'll put you in a little team. Check out the event, theres a scoring system on there for teams and individuals etc.
Get excited! Should be a cracker.
Not sure TBH!
If you haven't got your L2S make sure you get on the deallll. We'll have forms on the day etc.
Should be a fun day. It's sold out now, pending a few payments from guys..
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
