Hey guys,
Just a heads up - we have a FEW spots left for our Winton day. This time we're not letting anyone else co host the event (We had some issues in the past with other clubs not being able to run events to our standards) and will be doing it on our own as per usual.
If anyone came last year we had a fantastic turnout and fantastic event, cars got amazing amounts of track time etc
$195 entry for the day.
First 30 newbies/L1/come and try entrants will get a FREE upgrade from a L1 day license to a YEARLY Level 2 Speed license! (10-15 gone so far)
Less than 10 spots left!
https://www.facebook.com/events/228418254329884/
P.S You DONT need to be a Uni student (name is more of a tradition thing for our November track event) if SAU gets 5 or more people we'll put you in a little team. Check out the event, theres a scoring system on there for teams and individuals etc.
Get excited! Should be a cracker.
Not sure TBH!
If you haven't got your L2S make sure you get on the deallll. We'll have forms on the day etc.
Should be a fun day. It's sold out now, pending a few payments from guys..
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
    • if need be I guess I will, yeah. Just to be clear, it's okay to use the sill area around the jacking points for loading, meaning the actual pinch weld or jacking point just sits in the slot without taking on any weight?
    • No. No it can't. It will absolutely end badly. There's no need for it, so there's no need to create the risk. Mitigating a risk that didn't need to be there in the first place is even dumber than mitigating a risk that could be engineered out in the first place. And the risk has already been engineered out.
    • You can also make your own. It doesn't need to be rubber. It just needs to mate securely enough to whatever the jack/arm point is, and have a slot in the top. If that means welding a few chunks of steel together, or slotting something in a mill, then, that's what it means.
