Hey Gents
As the car is warmed up not only coolant temp but also oil temp, say around 80-90  degrees the car starts to have a misfire.  At first its just a hiccup at idle but then progressively gets worst as I keep driving and the engine warms up more.  From idle to 1500 rpm the response is terribly.  It's extremely hard to take off from a light, and the whole drive line shudders as I attempt to get the car moving but as soon as 1600 rpm rolls around it goes back to absolute normal with no problems all the way WOT and mind you this only happens when the oil temps are at operating temps avg 85 degrees.  Does this seem like an igniter issue?  or coil pack issue.  Whilst this happened, I had the car on the driveway with the engine running and I sprayed freeze spray directly onto  the igniter with no change.  From 1600rpm and up theres no issue, regardless of coolant and oil temp.  My intent is to go r34 gtr smart coils and get the wiring specialites adapter harness and be done with it,  just hope this helps.  Thanks guys
https://www.sau.com.au/forums/topic/472608-r32-gtr-idle-misfire-when-hot/
haltech plug in.  has been tuned for 2 years, this is the first time it has given me trouble.
single turbo
maf deleted running onboard map sensor
gm iat
update= the car now is unable to rev past 2000rpm, just struggles to rise to 2000rpm, sounds like anti-lag(double hecked its not activated).
can a failing ignition system change symptoms so erratically?
update: Started again this morning no faults revved to 5-6000 no issue, ran for about 10 mins, I shut it down.  Went inside to have a bite and then come back out to start it and the problem re-appears.  Seems something gets heat soaked and it struggles to get to 1750 rpm from idle, then as it approaqches 1750rpm, it will clean right up and rev no problem.  During the stumbling, the afr gets really lean basically offscale.  If it was a vacuum leak would the engine rpm be higher?  I see no decrease of vacuum on my aem boost gauge, it sits at a steady 20in/hg.
  • 3 months later...
hey guys
update, so in went new coils and no joy, same symptom when hot.  I opened up the cas and found a whole bunch of rust dust inside, bearing seems shot.  blast of air, back on car and it seems good now.  no more bucking or loss of power.  no my other question is how do i rebuild a hitachi cas(r32/r33 style.  not the black one on the r34)?  i pulled off the cover which mounts to the cas bracket but the guts of it dont seem to want to conme off even after removing the screws.  any ideas guys?
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I can do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not! It's well within the service manual specs...but they are very open
