Hey fellas, hope you're all well
so here we go I need help
I rebuilt my R33 series 2 GTS-T from the ground up.
The rebuilt motor is having trouble starting and idling.
Rebuilt RB25DET series 2
Car kicks over then cuts out straight away, like its starved of fuel. Then when you try start it again it gets really compressiony doesn't want to start. Leave it for a min and it will, but with horrible misfire, eventually sorts itself out but not fully, hunts for a bit. Doesn't sound like it's running on 6 cylinders.
Head got rebuilt, had no issues with old one, piston rings were finished so I had to rebuild it
Compression ratings at 140 across all 6
Seems to be over-fueling but it's always run rich.
I've checked the:
 Coil pack loom, tested fine
 Fuel pressure fine
 Oil pressures good
 Spark is fine
 Timing is spot on
New
- Walbro fuel pump
- Saads fuel reg
- Iridium spark plugs
- AFM
- K&N Oil Filter
- Gates timing belt
- Nissan water pump
- Nissan thermostat
Old (off the motor before rebuild, but were working when dismantled)
- GCG high flowed turbo
- GCG FMIC
- Injectors and rail (standard series 2)
- ECU (standard series 2)
- Intake manifold (inc AAC)
- Exhaust manifold
- Exhaust
- BOV
- Alloy Radiator
- Cam shafts
- After market boost controller
- CAS
- Pod filter
- Splitfire coilpacks (haven't travelled more than 3000km)
Any suggestions for me to test?
I'm trying to organise a new CAS to test.
We were test driving the car all week in our workshop carpark after we installed the new reg and it was running really well, but was doing this same thing over a week ago. Kinda reverted to doing the same thing again unfortunately.
Id appreciate any help with it, it's so close but so far omg
Thanks for reading
Marni
Air and fuel, air and fuel
Check leaks as above
And possibly injectors not seated/connected properly or leaking/fked
AFM plug all good?
Stock ECU may not be happy with that regulator if it's upped the fuel pressure
Also not impossible to have a splitfire shit itself
You say it sounds like it's not running on all 6 - pull coilpacks and see if you can isolate which cylinder isn't happy, as that will narrow things down to a specific injector/coil/plug rather than overall engine air/fuel delivery issue
They all seem to be working fine, it's like as soon as it cranks and starts, gets oil pressure then dies straight away, sounds promising for like 1 second and then cuts straight out
im wondering if it's a lazy lifter or something
although when i installed the last head and had a stuck lifter I had no comp in that cylinder whatsoever
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
