Hey fellas, hope you're all well
so here we go I need help
I rebuilt my R33 series 2 GTS-T from the ground up.
The rebuilt motor is having trouble starting and idling.
Rebuilt RB25DET series 2
Car kicks over then cuts out straight away, like its starved of fuel. Then when you try start it again it gets really compressiony doesn't want to start. Leave it for a min and it will, but with horrible misfire, eventually sorts itself out but not fully, hunts for a bit. Doesn't sound like it's running on 6 cylinders.
Head got rebuilt, had no issues with old one, piston rings were finished so I had to rebuild it
Compression ratings at 140 across all 6
Seems to be over-fueling but it's always run rich.
I've checked the:
 Coil pack loom, tested fine
 Fuel pressure fine
 Oil pressures good
 Spark is fine
 Timing is spot on
New
- Walbro fuel pump
- Saads fuel reg
- Iridium spark plugs
- AFM
- K&N Oil Filter
- Gates timing belt
- Nissan water pump
- Nissan thermostat
Old (off the motor before rebuild, but were working when dismantled)
- GCG high flowed turbo
- GCG FMIC
- Injectors and rail (standard series 2)
- ECU (standard series 2)
- Intake manifold (inc AAC)
- Exhaust manifold
- Exhaust
- BOV
- Alloy Radiator
- Cam shafts
- After market boost controller
- CAS
- Pod filter
- Splitfire coilpacks (haven't travelled more than 3000km)
Any suggestions for me to test?
I'm trying to organise a new CAS to test.
We were test driving the car all week in our workshop carpark after we installed the new reg and it was running really well, but was doing this same thing over a week ago. Kinda reverted to doing the same thing again unfortunately.
Id appreciate any help with it, it's so close but so far omg
Thanks for reading
Marni
Air and fuel, air and fuel
Check leaks as above
And possibly injectors not seated/connected properly or leaking/fked
AFM plug all good?
Stock ECU may not be happy with that regulator if it's upped the fuel pressure
Also not impossible to have a splitfire shit itself
You say it sounds like it's not running on all 6 - pull coilpacks and see if you can isolate which cylinder isn't happy, as that will narrow things down to a specific injector/coil/plug rather than overall engine air/fuel delivery issue
They all seem to be working fine, it's like as soon as it cranks and starts, gets oil pressure then dies straight away, sounds promising for like 1 second and then cuts straight out
im wondering if it's a lazy lifter or something
although when i installed the last head and had a stuck lifter I had no comp in that cylinder whatsoever
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
    • sensible choice....and all 32s should be in yellow
