Gidday.
As suggested I require some help in working out my comp ration. I have researched the heck out of this subject and have found some really good posts with very VERY detailed information and processes in order to a quote this information. But nothing about how to adjust the ratio. For instance from what I have found the RB25DET S2 Came out with a 9.0:1 Ratio from factory also here are some other specs I have found for a stock RB25DET.
SIZES ARE IN MM AND ALL FACTORY.
BORE SIZE             : 86.0MM
STROKE                 : 71.7MM
DECK HEIGHT      : 188.5MM
HEAD CC              : 66.5MM
COMP HEIGHT   : 31.5MM
So here is my information
RB25DET S2 Block.      Decked 10 thou
Rb25det S2 Head.        Deckedb10 thou
Bores.                            +20 thou
Stroke  (Stock)              71.7mm
I am looking for between  8.5:1 to 8.8 - 9.0:1
I am not as smart as some and cannot seem to figure this calculation method out. The instructions and walk throughs I have seem are really detailed but a little TO detailed to the stage where I am lost and it all starts looking like the matrix wall paper screen saver.
So if someone could help me understand and to figure out what pistons I should her what Head gasket and so I will be forever in your debt.
I had my rb25det with full stock internals up to 444.4 RWHP @ 19.5 @ 19.5PSI Of boost and snapped piston 1-s Ring Landings.
Thank You In Advance.
https://www.sau.com.au/forums/topic/472644-rb25det-comp-ration-help/
On 11/11/2017 at 8:34 PM, KiwiRS4T said:
Stock is fine 9 to 1 is fine ...properly assembled and tuned CR will not be the cause of engine failure.
I am trying to ascertain the compression ration I have now as compared to the stock 9 to 1.
9 to 1 i if everything is factory.
I have a 10 thou decked head
10 though decked block so that would raid my compression to 10 to 1 and over.
But if I use a 1.3mm gasket it will lower my compression.
I am guessing lower then 8.5:1 andbdeffinatlu lower then 9.0:1
If I use a 1mm head gasket it to will lower the comoression ratio but to what I do not know.
My guesses and assumption are basses upong the given information.
Standard is 9.0:1.
Deck head 10thou and block 10thou so if everything else is stock it would mean that my compression height is 20thou or 0.5mm shorter and my piston now comes closer to the valves and the head meaning higher compression.
If I try to compensate for the 20 thou differance and use a 0.5mm or 20 thou head gasket it should in theory bring my compression back to stock (9.0:1) If I use a 1mm or 40 thou head gasket it would mean that my compression height is now lower then 9.0:1 as the pistons are now 20 thou lower at TDC which inturen will lower my comp ratio.
If I use a 1.3mm or 51.118 thou
Meaning my comp height is now 30+ thou taller meaning my comp is now lower.
So
With all this information I still cannot work out my assumed comp ratio.
I'm guessing that with a 1mm (40 thou) MLS Gasket my comp will be lower then 9.0:1
And a 1.3mm (51thou) would make it lower.
But I need to know what it would be lower to.
So if anyone here and I am seriously confident there is.
Has done this
● what type of pistons were used and
● what size head gasket was used. And
● Comp ratio was achieved.
Thank You.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
