Hey everyone,
So 2 of the rims that came on my car when i brought it have now cracked in the same spot, so figured i may as well buy all new wheels. i've spent a couple hours last night searching the wheels and offset thread, found alot of good information but couldn't find enough to get a proper answer.
I am looking at getting some Rota P1R wheels. having some trouble making sure i've got the right offsets tho.
The choices are the following
18x9.5 +27
18x9.5 +35
18x9.5 +38
Have compared my current to the the following on WillTheyFit.com, but still not sure which would be the best choice, i think the +27 on the front would stick out to much but not sure if the +35 would be to close on the inner.  But i think the +27 would fit the rear pretty nice, Going to jack the car up this afternoon and try and check clearance.
Just wondering if anyone knows off the top of their heads the best offsets to get?
Cheers in advance.
Hey mate.
They're basically perfect, as I have 9.5 and +27 all round. You WILL need to roll/lip the guards if you want to run chunky tyres. I run 265's all round and I do not get scrub and I mean that will barely fit.
The 9.5 +38/+35 will hit at the front. Need a spacer.
IMO, the +27 at the rear pokes more than the front does, I was suprised that when putting same wheel size on all 4 the fronts natrually are a little more in.
I want a 10+38 on the rear so I can run a 285/295 for max tyre.
So ultimately, you may need a spacer or two if you go for the +35/38 combination, the 27 will max it out. 35 with some spacers/extended studs will get it to sit in a little.
Awesome, exactly what i was looking for, i was a bit worried about the front inside hitting the suspension arms but seems it will be okay :)
i will be running 245/40/18 on the front and 265/35/18 on the rear.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
