34 GTR, came with BC External Reservoir coilovers, subframe collars and whiteline rear sway bar.
Came with 275 cheap tyres, Achilles Sport something, 400 tread wear, not fantastic.
Car is 99% street driven and the ride is way too firm for that, on the track day I did, car wanted to understeer quite easily an low speeds, rear seemed like it had bulk grip. Stock arms so -1.5 front camber, -2 in the rear.
Justjap/BC said don't change spring rates on BCs as they are not valved for that, I'm not sure if mine are 8/6 or 9/7 which is the 2 standard flavours.
MCA recommends Street Performance (purple ones) with 11/5 spring rates. They're about 2k.
Shock works says "our street setup" which is a bit cheaper but hasn't provided any idea on specs.
Can I just go ahead and drop some lower rate springs in? How do I properly confirm current rates?
Any reviews of MCA street performance in a GT-R? 11/5 seems like an odd spring combo and makes me think it'd want to understeer.
Any info on what the Shockworks street setup is?
New shocks are cheaper than on roads for another car :)
With my R34 i ended up with MCA Reds with 12kg/5kg springs - dampers were valved for tarmac rally/hillclimb rather than circuit/track
Came from M-Spec stock suspension which was surprisingly jarring on sydney roads, the MCAs were an improvement in ride-quality both when driving quickly and at the speed limit.
I went with MCA as they had done speciifc model testing on the R34, where i believe shockworks' test car was a R32 GTR.
Another option to consider is PSS9 bilsteins which are a good choice off the shelf, and can be bought and serviced in Sydney by Heasmans
Some info might be useful from my thread.
Edited by JGTC
That's encouraging, that they were better VS standard suspension.
When you say ride quality, what does that mean to you?
To me it's primarily about how harsh the car rides over bumps/joins/imperfections in the road.
Seems a little counter-inuitive.
Bad tyres, uncomfortable shocks, but you seem to want a great road ride that's also great on the track? There's only so far that is even possible.
MCA or Shockworks will do what you want however. Shockworks will be cheaper, but BC ER's aren't actually that bad and I'm not sure you'd notice some world of amazing difference, the changes are going to be subtle, there's no way around the fact that making it softer on the street will make it softer on the track.
Everyone has rave reviews about physically calling MCA and talking to them (Josh gets a good rap) so it's probably worth just picking up the phone with an idea of what you really want out of this particular car. The cost is high but everyone seems to say its well worth it in the end.
BC ER coilovers are the wrong choice for street driven comfort period.
BC specify that the ER's are designed for 100% track use only so I don't believe you'd be satisfied after changing spring rates.
A set of BC BR-RS (Rubber top mounts) would be the way to go in regards to street comfort out of your BC options.
Spring rates like that will give you three things:
1 Understeer.
2. Good traction.
3. Harsh front end.
Essentially if you don't get bored understeering around corners you will get good traction if you can ever get on the gas.
If you look at Nismo S tune spring rates you will see they are higher on the rear than the front. 6.0kg/mm front 6.7kg/mm rear.  Much more sensible rates.
Did notice that, which seems to make more sense to me given the car is also dialed for more rear camber from factory.
Everybody tells you there setup is best =\
Not easy to just go for rides in everyone elses GT-Rs when you're not in the CBD.
Spring rates are only part of the puzzle. What's the valving like? What viscosity fluid is used?
Over the years I have run stock V spec, Nismo S and R tune... then finally cracked it and did it properly. 14 kg/mm front springs and 9 kg/mm rear but the valving in them is far from "normal". Around town and bumpy "shit Sydney roads" it soaks all that stuff up MUCH better than the 3 gastric junk setups before it.
Long story short, looking at one part of the shock is pissing in the wind and a waste of time!
  • Like 2
I had shockworks in my R34 GT-T, definitely not bad at all comfort wise with their standard rates. I wouldn't call it comfortable however.
Have had a set of BC V1s in my previous car and ridden in countless cars with BC BRs, only purchase these if you have $1300 to spend. If you're spending $1300 on coilovers for a R34 GTR I think you need to reassess your priorities. I see countless 50k+ builds running BCs and cry a little.
I've driven a MX5 with X-R coilovers with their 'Tarmac' spring rates and was pleasantly surprised with comfort and performance. Going off this I can only guess that X-C would be significantly better.
TLDR
- Buy BC BR if budgeting ~1300, don't cry when they ride shit.
- Buy MCA X-C with suitable spring rates if you want decent comfort (or fork out for reds), just talk to MCA.
  • Like 2
6 hours ago, ActionDan said:
"MCA recommends Street Performance (purple ones) with 11/5 spring rates. They're about 2k."
Sorry mate, don't know how I missed that. Is purple their new blue? Blue was about $1,600 from memory.
maybe have another look at their site too as they've recently changed their offerings
  • Blues
  • Street Essentials
  • Street Performance
  • Street Ultimates
  • Race Prime
  • Race Red
with a number of default spring options, with Comfort recommended as 9/4 as opposed to the 11/5 for performance
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
