Has anyone ever put Evo 9 wheels on there R32? I have an R32 GTSt and i have some access to a set of Evo9 wheels relatively cheap. Here in the states R32 GTR wheels are far and few between and expensive when you do find them. Same with R33 GTR wheels.
As far as i can tell the stock R32 GTR wheels are 16x8 +38 offset, while these Evo 9 wheels are 17x8 +38 so i dont see why they wont fit but maybe someone knows something i dont?
I had a friend do a quick photoshop with Evo VII wheels and Evo IX wheels.
https://www.sau.com.au/forums/topic/472669-evo-9-wheels/
51 minutes ago, niZmO_Man said:
They'll be fine. It'll look a little 'sunken', but if you don't care about that, Evo wheels are a great buy.
They couldnt look anymore sunken than the stock GTSt wheels eh.
I appreciate the help! These cars arent that well known yet here so it can be quite a pain digging up info
https://www.sau.com.au/forums/topic/472669-evo-9-wheels/#findComment-7858946
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
