Our Mazda CX7 needs new front disks soon. We're driving to Jindy in January so I'd like to have new ones by then.
Because I absolutely just can't replace part for part and NEED to upgrade I started looking at whether I could improve the brakes at all with some OEM items from another Mazda. And I can!
The CX9 and CX7 Diesel both have 320mm disks compared to my CX7's 296mm. The only difference for the bigger disks are that the caliper brackets are larger. This means that with the larger brackets, I can run 320's.
The problem is that the brackets are $270ea from a dealer and the 3 or 4 wreckers I've asked don't have them.
So while I really want to do this upgrade I'm wondering whether its actually worth it. Will 24mm greater diameter with the same calipers actually make much difference?
Thanks guys,
Christian
Well 32 33 gtrs are 280mm and vspec brembos are 320mm arent they?
Personally i havent done the upgrade so i cant say first hand but to me i dont think its much of an upgrade.
Considering the car its going on i doubt you would even notice the difference city/traffic driving.
Decent disc/pad change with new fluid. Cheap. Cheerful.
It would make sfa difference on the street on a runabout car such as your cx7. If you where racing it or doing hill runs, the bigger disc would help dissipate heat better and retain ultimate braking for longer. If the brackets where cheap, i would say do it but at 270 each, not worth it unless you get some from a pick a part type wrecker for cheap cheap.
As said above, decent pads and fluid will make the biggest difference and is where I would spend my money.
3 hours ago, Dose Pipe Sutututu said:
Get better pads and you'll be sweet :)
Also shameless plug, can get you decent deals on DBA stuff
lol offering trader services to THE Admin without paying for SAU trader status :4_joy: bold move.
hahaha admin wins, gets mad prices lol and if my car is ready he can take it for a skid too ololol
Interesting scenario, can we perhaps negate car model and discuss the extremes to highlight attributes associated with big vs small rotors?
Theoretically, as mentioned above disc size would increase the potential limit of heat absorbtion and dissipation through increased thermal mass. Would material also affect the rate and limit of which the disc could convert force into heat?
If discs were thicker they would also be able to accommodate larger vanes increasing cooling surface area.
I think also being more further away from the axis the braking moment (as in force over distance) would be increased, increasing stopping power but also may promote locking up?
I forget, is unsprung weight a good thing or bad thing for handling? Larger brake disks would weigh more, statically lowering the centre of gravity but because not a rigid connection to the chassis may also be a disadvantage in a dynamic situation?  Would rotational mass of rotor be negligible due to being so close to the axis?
Heavy front rotors would take the trajectional force better under extreme application than lighter rotors, right? This would provide more stability on hard braking when the nose dives onto the front axis?
I don't know, just curious. Any experts in this field?
  • Like 1
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
