Our Mazda CX7 needs new front disks soon. We're driving to Jindy in January so I'd like to have new ones by then.
Because I absolutely just can't replace part for part and NEED to upgrade I started looking at whether I could improve the brakes at all with some OEM items from another Mazda. And I can!
The CX9 and CX7 Diesel both have 320mm disks compared to my CX7's 296mm. The only difference for the bigger disks are that the caliper brackets are larger. This means that with the larger brackets, I can run 320's.
The problem is that the brackets are $270ea from a dealer and the 3 or 4 wreckers I've asked don't have them.
So while I really want to do this upgrade I'm wondering whether its actually worth it. Will 24mm greater diameter with the same calipers actually make much difference?
Thanks guys,
Christian
Well 32 33 gtrs are 280mm and vspec brembos are 320mm arent they?
Personally i havent done the upgrade so i cant say first hand but to me i dont think its much of an upgrade.
Considering the car its going on i doubt you would even notice the difference city/traffic driving.
Decent disc/pad change with new fluid. Cheap. Cheerful.
It would make sfa difference on the street on a runabout car such as your cx7. If you where racing it or doing hill runs, the bigger disc would help dissipate heat better and retain ultimate braking for longer. If the brackets where cheap, i would say do it but at 270 each, not worth it unless you get some from a pick a part type wrecker for cheap cheap.
As said above, decent pads and fluid will make the biggest difference and is where I would spend my money.
3 hours ago, Dose Pipe Sutututu said:
Get better pads and you'll be sweet :)
Also shameless plug, can get you decent deals on DBA stuff
lol offering trader services to THE Admin without paying for SAU trader status :4_joy: bold move.
hahaha admin wins, gets mad prices lol and if my car is ready he can take it for a skid too ololol
Interesting scenario, can we perhaps negate car model and discuss the extremes to highlight attributes associated with big vs small rotors?
Theoretically, as mentioned above disc size would increase the potential limit of heat absorbtion and dissipation through increased thermal mass. Would material also affect the rate and limit of which the disc could convert force into heat?
If discs were thicker they would also be able to accommodate larger vanes increasing cooling surface area.
I think also being more further away from the axis the braking moment (as in force over distance) would be increased, increasing stopping power but also may promote locking up?
I forget, is unsprung weight a good thing or bad thing for handling? Larger brake disks would weigh more, statically lowering the centre of gravity but because not a rigid connection to the chassis may also be a disadvantage in a dynamic situation?  Would rotational mass of rotor be negligible due to being so close to the axis?
Heavy front rotors would take the trajectional force better under extreme application than lighter rotors, right? This would provide more stability on hard braking when the nose dives onto the front axis?
I don't know, just curious. Any experts in this field?
  • Like 1
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
