Our Mazda CX7 needs new front disks soon. We're driving to Jindy in January so I'd like to have new ones by then.
Because I absolutely just can't replace part for part and NEED to upgrade I started looking at whether I could improve the brakes at all with some OEM items from another Mazda. And I can!
The CX9 and CX7 Diesel both have 320mm disks compared to my CX7's 296mm. The only difference for the bigger disks are that the caliper brackets are larger. This means that with the larger brackets, I can run 320's.
The problem is that the brackets are $270ea from a dealer and the 3 or 4 wreckers I've asked don't have them.
So while I really want to do this upgrade I'm wondering whether its actually worth it. Will 24mm greater diameter with the same calipers actually make much difference?
Thanks guys,
Christian
Well 32 33 gtrs are 280mm and vspec brembos are 320mm arent they?
Personally i havent done the upgrade so i cant say first hand but to me i dont think its much of an upgrade.
Considering the car its going on i doubt you would even notice the difference city/traffic driving.
Decent disc/pad change with new fluid. Cheap. Cheerful.
It would make sfa difference on the street on a runabout car such as your cx7. If you where racing it or doing hill runs, the bigger disc would help dissipate heat better and retain ultimate braking for longer. If the brackets where cheap, i would say do it but at 270 each, not worth it unless you get some from a pick a part type wrecker for cheap cheap.
As said above, decent pads and fluid will make the biggest difference and is where I would spend my money.
3 hours ago, Dose Pipe Sutututu said:
Get better pads and you'll be sweet :)
Also shameless plug, can get you decent deals on DBA stuff
lol offering trader services to THE Admin without paying for SAU trader status :4_joy: bold move.
hahaha admin wins, gets mad prices lol and if my car is ready he can take it for a skid too ololol
Interesting scenario, can we perhaps negate car model and discuss the extremes to highlight attributes associated with big vs small rotors?
Theoretically, as mentioned above disc size would increase the potential limit of heat absorbtion and dissipation through increased thermal mass. Would material also affect the rate and limit of which the disc could convert force into heat?
If discs were thicker they would also be able to accommodate larger vanes increasing cooling surface area.
I think also being more further away from the axis the braking moment (as in force over distance) would be increased, increasing stopping power but also may promote locking up?
I forget, is unsprung weight a good thing or bad thing for handling? Larger brake disks would weigh more, statically lowering the centre of gravity but because not a rigid connection to the chassis may also be a disadvantage in a dynamic situation?  Would rotational mass of rotor be negligible due to being so close to the axis?
Heavy front rotors would take the trajectional force better under extreme application than lighter rotors, right? This would provide more stability on hard braking when the nose dives onto the front axis?
I don't know, just curious. Any experts in this field?
  • Like 1
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
