Selling Engine/Transmission combo as going 3.0LT/2.8 and sequential (Open Class Track Car)
Built rb26 for sale (under 1000kms)
Completely blue printed and clearances set + bearings supplied by Orger Engines in Bayswater (old winfield GTR builders) (all paperwork and invoices available for build)
Assembled by myself @ RaceEquipped
Engine is complete ready to bolt in and connect up. (minus Hotside and coilpacks)
Was at 353KW on run in for close to 12months with 0 issues, car was redynoed 2 months ago by chequered tuning, with spark blow out at 360KW @ 6000rpms only (shooting for 9-9.5k RPM), car has been parked, motor pulled out for getrag conversion, rewiring job, engine bay stitch weld, front tube end, ignition system etc. it Is a reliable 500-550KW Build
HEAD (New R34 GTR Casting)
COMPLETELY Reconditioned Head (cracked tested etc also)
- TOMEI Dual Valve Springs
- TOMEI Retainers
- TOMEI Buckets
- TOMEI Metal Intake Gaskets
- HKS 272 10.8MM Lift Cams (head modified to fit)
- New Rocker Cover Gaskets
- Adjustable Cam Gears
- All Reshimmed
- New Cam Seals
- New Intake Valves (standard exh)
- 3 Angle CNC Valve Seat Cuts
- Guides (New OEM Nissan and Bronze)
- Cam Covers
- Head Drain
- 1600CC injectors
- ALL New Water hoses
BLOCK
- Torque Plated, Honed, Tunnel Bored, Crack Tested, Tanked ETC
- Ross 86.5MM pistons (HPC Coated) and H Beam Rods
- ACL Race Bearings throughout
- Short Nose Crack sleeved with long nose collar
- N1 Pump + Reimax Oil Pump Gear
- Full Balanced Rotating Assembly
- Extended Sump (6LTish sump)
- Tomei Sump Baffle with drilled out rear returns
- ARP Headstuds
- Tomei Head restrictor
- Tomei Headgasket
- New Timing belt kit
- New Water Pump
$9000 For Motor
R34 GTR Getrag GBox $7500
- Gearbox
- Front shaft
- Tailshaft
- Flywheel
- Nismo Used Twin plate Clutch
We all know the mighty Getrag has known to hold 1000HP
(Missing shifter, Crossmember and clutch fork, these can be found brank new and is $600-700 for them off AMAYAMA.com or from Nissan JAPAN have all partnumbers)
$15.5k for both box and engine.
0403485395
  • 8 months later...
On 8/23/2018 at 10:53 PM, GRKGTR said:
I know old post but is box still available?
there a getrag on gtr parts page on fb. low km but no tailshaft i think
7.5k
@reaper
  • 1 month later...
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
