Hi guys,
I have up for grabs my OS Giken OS88 6 Speed sequential gearbox. This was originally purchased in October 2014 and received June 2015 after an 8 month wait from OS Giken.
This is the updated version with the extended sump on it.
I optioned this up with "option 2" gear ratio's. (This is an extra $1,000 option over the standard box price). This has the shortest 1st and the tallest 6th (6th same as the factory R32/R33 GTR 5th speed) so it's not spinning higher than it needs to be on the freeway. The ratios are;  Option 2: 2.890, 1.981, 1.468, 1.174, 1.000, 0.757.
I have also upgraded the gear position sensor to a Novotechnik Item as shown in the photo's below. This does away with the OSG 'switch style' sensor.
The box has done no more than 350 km's on the street and a full flex tune on the dyno, so it's as good as brand new. Motul 75W-140 fully synthetic oil was used. That was the product recommended by Award Diff and Gearbox. It will not be driven again apart from the 15-20 odd Km's to where it will be removed.
Whats included?
- OS-88 6 speed sequential gearbox - Option 2 ratio's.
- OS-88 transmission crossmember for BNR32/BCNR33
- Novotechnik gear position sensor
- OS-88 Adjustable release fork kit
- OS-88 direct shifter kit (bent style)
- Release bearing
- Gear indicator
The gearbox is currently in the car and will be removed within the next couple weeks. I will be happy to take someone for a demonstration drive, HOWEVER, not without a $2,000 deposit. If you're interested in the gearbox you will (well should) know what they're about. The transfer case in those photo's is NOT included. I need that!
Apart from the clutch (I used the OS Giken R3C) this is a whole and true bolt in package.
Location is Georges Hall, Sydney. I will post at buyers expense.
Contact me VIA PM.
Price is $16,000
  • Like 2
  On 23/11/2017 at 9:45 AM, I will said:
10k cash
Expand
I will speak on Pauls behalf...... wake up mate you're Dreaming!
Edited by Mick_o
  • Like 1
Why do people think cash in a private sale has some mysterious pulling power lol, it's not taxed, so what else you gonna pay with...Bitcoin?
Paul chuck the ad on the Pommy site. With them buying in pounds to the aussies peso you might get more sniffs.
Freight to Europe easy to sort but import tax to UK would rip anew orifice.
Worth a go as going to be one of those slow sells as unique piece of equipment and will only suit a refined buyer or drug dealer.
  • Like 1
  On 24/11/2017 at 10:14 PM, Mick_o said:
Or how "cash" makes it worth 40% less than the asking price? ?
Expand
You don't understand high finance Micko, Brett's and many other blokes $1 "cash" is worth $1.45.455 to them , easy :pirate: I think lol
Nice try Brett, no wonder you could build that beaut car :17_heart_eyes:
  • Like 1
  • Haha 2
  On 27/11/2017 at 12:42 AM, Mick_o said:
Yes! Thats why he gives it all to the GTR ?
Expand
haha, thats not bad for a bloke with a massive hangover , I guess :nyaanyaa:
Bet Heckle is feeling no pain
Hi piggaz.. if you dont mind can i know the novotechnik sensor work well? do you connect them back to OS gear indicator as well or run other type gear indicator? I think mine f***, plan to replace them when remove next time. what model are they?
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 馃槄
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
