I'm looking at one of these kits for a V36 350gt that didn't come with the factory cruise control. Has anyone used one of these kits and can comment on them? Bit exxy but I do alot of highway driving so I want to have something.
http://www.sinergymotorsports.com.au/cart/products-page/nissan-skyline-v36/accessories-cruise-control-nissan-skyline-v36/
https://www.sau.com.au/forums/topic/472735-sinergy-cruise-control-kit/
I haven't used that particular kit, but that is not expensive - that is about the going price for a decent drive-by-wire cruise setup. And it includes the oem steering wheel switches, which would be a decent amount of that cost. Synergy have been around for a long time and quite a few people swear by them. They are predominantly a car yard, so I generally don't trust them as far as I could kick them, but for stuff like this they are trustworthy imho.
I got an aftermarket cruise control / throttle controller for about half the price I never got around using as car was sold ages back.
Positive  point- it is also a throttle controller and its v36 specific plug and play installation
Negative point- not oem looking like the one you posted
Sorry, I already bought the Sinergy one
  • 2 months later...
Does anyone have one of the switches and surround for sale like the ones pictured?
I contacted Chris but had no reply, so here's hoping someone here has one.
If you can reply with a picture and price, thanks
  • 3 weeks later...
Just purchased the Autostrada E-cruise kit for my KV36. Looks like a fairly easy install, might tackle it this weekend if time permits. Does anybody have any tips before I begin? Just drop the earth off the battery so I don't accidentally blow the airbags then get busy? Cheers, thanks in advance
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
