This is my setup. There is a boost a pump unit that does 17.5v when active and a continental pump control module. these sit where the stock fuel pump resistor module lived under the ABS/atessa ecus. Tested at 20v/20a for a few hours 100% duty no problems. The relays are for power and the normal/high voltage signal for boost a pump. pump is a Pierburg L3LM screw pump.
Was a bitch to get into the r34 saddle tank but I have magnets to hold the hydramats in place. the hydramats cover basically all of the driver side saddle floor.
The sard jet pump return line (not shown here) is pointed right onto both the hydramats to keep them wet.
Notice the split hydramats feeding the pump. If the mats were damp (hence the jet pump return flowing directly onto both mats) there is enough surface tension to only suck from submerged sections of hydramat. You can have one corner of only one of the mats submerged in fuel and it sucks up no air.
The t-piece join is only 5cm vertical from the mats so very little suction head difference.
Edited by burn4005
  • Like 2
Pump works, I haven't got it to a track yet to see. Am logging fuel pressure with a engine protection function on injector delta so I'm not worried about my engine.
I haven't changed any of the venting. The charcoal canister line is still in place which is for fumes leaving the tank. The fuel cap is the vacuum relief and I've tested it is working correctly, are you saying it is inadequate? It allows air in to the tank once it gets to between to -3.3 to -6 kPA of vacuum according to the manual.
The 2200 is a natural gas injector and hopeless on liquid fuel.
The 1650 is a Bosch Motorsport injector designed for liquid fuel and is all stainless steel inside. (Really only flows ~1500 at 3 bar)
Edited by burn4005
  • Like 2
As mentioned earlier in the thread, it is a good idea to upgrade the venting when upgrading pumps.
On a standard fuel tank, is it possible to get a vented fuel cap? Where is everyone mounting their upgraded vents? Being one of the highest points, can it be installed inear the top of the fuel filler neck? Or am i looking at this wrong?
Re injectors. I am aware the 2200 is a cng injector. I know people who run both, particularly on e85. Neither seem to really have a problem... unless they arent telling me lol
I got an alloy hat spun up, drilled and tapped threads for the fittings. I ran a -12 breather with a "roll over valve" so air can only come in the tank. (No fuel smell).
expensive? Yup....
Heres 2 reasons not to run the 2000's these came outta my evo after around 10k km's. Car was bucking and surging and carrying on E85 of course.
Bosch 1550cc, often advertised as 1650cc (when run at 4 bar base) if you're on a budget. If not ID1700X and call it a day.
2000/2200cc CNG injectors are gay full stop, tried to road tune a set and they were awful.
I've been down this same road and it's a nightmare, I remember.getting blasted for do an over kill fuel system. sadly my last resort was an upgraded alternator. it didn't help much. but I guess it's a learning curve and expensive one at that.
Now my car just sits, move out and in my shop everyday even tho I like it so much, I'm sick to the stomach to drive it. I'm planning on re-doing the whole car. I'll go with a fuel lab variable pump next time. I'll spend a lot of time planning. of course I'll have to go with a Haltech ecu to manage it all. thanks for your thread. it was interesting to read.
  • 3 weeks later...
38 minutes ago, WantGTR said:
Ok so am about done with the fuel system bar a couple of small items.
I am using xspurt 1550s.
Well that tells us your injector choice.  The "small items" ie all the bits before the injectors are what I'd like to see details and pics for if possible.
Tank top hat, wiring, pump(s), pump control, jet siphon pump, reg, and lines.  That's all the good stuff IMO.
  • Like 2
Lol will get some pics up shortly
Starting from the tank;
1 walbro 460 with e85 submersible hose in tje stock fuel hat. From there an6 feed to the surge and an6 overflow back into the tank. An6 was the largest fitting i could get which would work on the stock fuel hat push on fittings.
2018-01-13_05-02-18
I ended up using a raceworks surge tank with 2 walbro 460s. The above will be covered up bit is just open for photo purposes. The tank comes disassembled but it pretty straight forward to put together.
2018-01-13_03-07-27
2018-01-13_03-07-11
From there all fittings are teflon lined braided hose, full flow an fittings from aeroflow. Theres about 2 dozen or more fittings. The tank is mounted to the body using rivnuts.
2018-01-13_03-08-06
Under the car is the fuel filter and bracket also mounted using rivnuts.
Moving along, where the old fuel filter used to sit now houses the the flex sensor bypass.
2018-01-13_11-29-17
Up front i am using a turbosmart fpr2000 as it has an8 fittings, aeroflow rail and xspurt 1550s which i sourced from scottys customs. The injectors fouled the balance tube a bit due to their height but i rotated them left or right so they clear and the plugs could reach.
2018-01-13_04-28-18
I have a couple smaller lines to make and am yet to wire it up but thats not difficult to do. Any fitting with an orb was replaced with a buna n o ring.
An ard alternator is currently somewhere between here and japan so that should make the system work happily. Thank all for your input and advice.
  • Like 2
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
