Upgraded Fuel System Questions
WantGTR
 Share
4 minutes ago, WantGTR said:
you bastards lol, i was 50/50 about this, knowing full well about the possible scenarios if i didnt upgrade. in anycase, RHDJapan will be getting yet another order from me.
Haha good man! ?
The added expense now will save you later on mate. ?
im running a similar setup to this.
Taarks surge tank with twin walbro 460 pumps staged ( DON'T RUN BOTH PUMPS FULLTIME )
255 walbro in tank.
turbosmart 1200 fpr
aeroflow big filter to rail
twin feed plasmaman rail
using only hardline due to the corrosive nature of e85, 2x  y blocks. oneway valve on the staged pump. running factory  fuel lines
  • Like 2
^^Nice.
Hows the stock alternator holding up lol?
i was considering the Taarks one. i think that surge is a tiny bit bigger than the raceworks. raceworks was a touch cheaper but didnt come with fittings so they are probably the same price. 6 of 1 half a dozen of the other i guess.
Yes pumps will be staged.
There is teflon lined hose which is rated for e85, that is what ill be using. i do like hard lines but ill end up making the bends all wonky and thats not gonna look good lol.
havent tested it yet  as im waiting for my turbo and ecu.
but am using power cables from a falcon or territory  and earth strap can pickup from wreakers for like $20. i think the alt will hang in there. hahhaha also running elec fans
  • Like 1
8 hours ago, bilk06169 said:
I like that a lot.  I'd be finding a way to put nylon or similar brace blocks between those lines to clamp them together, and then brace at least a couple of the longer ones to something rigid to prevent them from vibrating until they crack.  It will happen eventually on those ones on the surge tank.  Brace them out near the bends and avoid the E85 shower.
  • Like 1
I don't like the idea of staged pumps, especially with ethanol. Seen enough he said/she said where the 2nd pump giving up prematurely. Also, if your regulator isn't up to task you will get a spike in pressure when the 2nd pump kicks in.
Having said that, I also don't like the idea of running both pumps full time due to heat.
For these reasons, I run both my pumps (edit: not sequentially, derr) in parallel via a 100amp solid state relay, off PWM from the ecu (G4+). It works fantastically.
Edited by MagicMikeZ32
  • Like 1
Bilk, you're running twin walbro 460's down a stock hardline using the quick connect fittings at the tank hat?
the internal diameter of the hardline is probably only 6.5mm.
that sounds extremely restrictive to me
also, the only time I'd use staged pumps is with a fuel pressure sensor with an ECU that did injector delta pressure correction and a cutout function if it got too low.
I've got a bit of a frankenstein setup, running the following
holley boostapump runs normal voltage on 98 fuel, switches to 17.5v under boost when ethanol >10%
continental FPCM pump controller (from range rover/aston martin) takes a 100hz pwm control signal from ecu and produces a 20khz pwm pump driver
Pierburg L3LM screw pump (flows 430lph at 80psi - 17.5v)
powerhouse racing fuel tank hat with speedflow -8 supply and -6 return
Sard Jet Pump for saddle tank (much higher flow capacity to stock one)
dual holley hydramats in the tank, with magnets holding to floor, one is 15x3" straight (located where stock sock goes) and a 15x8" cross located in drivers side saddle. this covers most of the drivers side saddle floor.
rail return splits and flows back onto both hydramats to keep them wet. I am HOPING this totally eliminates needing a surge setup, looks totally stock, pump is quieter than the nismo due to being a screw instead of a vane and will do 500awkw, but we shall see!
Edited by burn4005
with 6an supply to the surge and as well as a 8an return to the surge surely that would be enough to keep the surge full?
best part is his stock fuel gauge will work with that fuel hat.
your fuel system seems to have a lot going on, what was the reason you didnt want a surge?
3 hours ago, sneakey pete said:
Twin intank pumps using the Frenchy's kit are the way to go for any kind of street car
Not cheap but by the time you do a proper surge tank setup you'd be coming off with a similar cost... and a setup in your boot.
I was considering the frencys setup but it was significantly dearer than the raceworks surge and youre doing all new lines anyway.
Mounting a surge is a bit annoying but dont really care about losing a corner in the boot as its not an everyday car.
Am a fan of the frenchy setup though.
1 hour ago, sneakey pete said:
I guess with raceworks you'd be up around 900 bucks instead of 1250 or so wouldn't you, so a little cheaper I suppose?
according to kudos 1805+post or am i missing something?
50 minutes ago, MagicMikeZ32 said:
The raceworks one looks cheap
it can look how it wants if it does the job what difference does it make? or should i have splashed out and bought a Radium or AI for the likes/follows?
Didn't realise you had purchased already. Agree it can look how it looks as long as it does the job. For me if I was going it, I'd pay the little extra for the nice stuff :) I don't have anything against raceworks, I use a shitheap of their fittings and lines in my car. Something as prominent as a surge tank in the boots tho... ;)
Thought i might add this here as its sort of relevant, picked up the bypass idea here too for the flex sensor so thanks guys.
I wont be using a surge tank as my car is street only so dont think ill need it.
Im using a walbro 460, i may need to run a second pump and when the time comes it will be mounted intank as well.
Using the standard hat with bulk head fittings for the cable and will be putting in a dash 8 fitting through the lid and new line up to the rail, ill put a T piece in the back of the fuel reg and run one to the flex sensor and back to the standard return line and the other will be returned to the tank using the factory feed line. Hope i have explained ok as it is usually lost in translation from brain to mouth, or finger in this case.
I hope it will make everything work and i have not overlooked anything.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
