18 inch 370z wheels for sale
full set of 4, fronts are 18 x 8 +43, rears are 18 x 9 +15, overall good condition, no buckles no cracks, tyres have 60% left, minor gutter rash.
$700
350z brakes, these are the bigger non-brembo 06+ brakes, front rotor diameter is 320mm, larger than R34 GTt rotors, good amount of meat left in them (reckon around 70%), came off a 08' 350z
Includes: rotors, calipers, pads, brake lines
specs below:
front rotor: 320x28mm; rear rotor: 308x16mm
Front caliper: dual piston; rear caliper: single piston
Cheap and a decent upgrade for non turbo skylines, fronts are direct bolt-on for r34 GT non turbo (with standard 14mm caliper bolt) and 03-06 non Brembo V35 and 350z (296mm rotors with single piston front and rear)
Will need to enlarge the holes on the hubs by 2mm to fit non turbo r33 and maybe some non turbo r34, however, still a decent upgrade for a small amount of hassle
Will not split the front and rear set, as it is cheap enough already
$300
Pick up only, as they are bulky items
Edited by chiksluvit
https://www.sau.com.au/forums/topic/472776-370z-18-wheels-350z-brakes/
