Hi all,
Earlier this year my 25 neo in my 34 did a head gasket during a track day. Had that fixed up and shortly after ran into more trouble which was diagnosed as rings. $6k and 10 months later with a freshly rebuilt motor I hit my 2nd track day of the year and the car has turned around and chewed through another head gasket on the first lap.
Motor was tuned, ran fine on the dyno in heat, didn't make as much power as pre rebuild but we attributed that to the hot weather.
Found shit loads of oil in the coilpack valley, after opening the bonnet up, but only in cyl 1-2, assuming this was spat out of the breather. Motor now has shitloads of blow by, is running on 5 and obviously is spitting white smoke out of the exhaust like crazy.
Trying to figure out how exactly it's managed to eat a head gasket (and do the rest of the damage it's done to my motor) after one hot lap of Winton. Coolant was boiling when I pulled off the track, powersteering was also overflowing (which set my manifold on fire, yay)
before anyone says check your temps, stock gauge said I was slightly above half, which is what I expected given it was a 35 degree day.
https://www.sau.com.au/forums/topic/472788-fresh-rb25-dead-after-1-lap/
This is just going to make people tell you the stock gauge isn't accurate enough track use
I've had a similar experience, except I cooked the bottom end bearings on the 2nd track day. And it had done run in kms plus a light track day on run in tune.
My oil pressure and temp gauges didn't pick up any issues, but they weren't monitoring in the spots with the problem....
Anyway, I learnt that building a motor doesn't always fix the problem that caused the motor to die in the first place.
In my case it was the external oil filter/cooler setup, which remained unchanged between motor builds.
What type headgasket? Thickness? What boost? Aftermarket headstuds?
Aftermarket radiator?
Its probably all conjecture and meaningless until you have worked out what your damage is.
So turbo is gone?
Loss of compression blown gasket or busted rings?  So are there results from a compression test and/or sniffer in the radiator if the thing still runs.
Is the bottom end ok?
Power steer can overheat and overflow but not after one lap usually.
Comes down to what is different between a dyno and the track. Oil surge is possible but unlikely to be fatal after one lap. Bad fuel and or fuel surge will cause problems more quickly.  Damage caused quickly is overwhelmingly combustion related rather than oil/coolant related.  The only other thing that fleetingly comes to mind is an over rev/over boost.
Its a depressing thought but more than one thing may have been busted.
Edited by djr81
So turbo is gone?
So we drained the oil out from the coilpack valley and the car actual runs smoothly and sounds good. doesn't misfire, sounds very much like compression is okay. Will be testing tonight or tomorrow when I can borrow a kit.
Only blowing white smoke under load so I'm assuming turbo is on its way out. Again, gotta pull that off in the next couple of days to figure it out.
Really just cant figure out the connection to the excessive blow by and the turbo going at the same time.
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
