BenjaminHJ93 Posted November 29, 2017 Share Posted November 29, 2017 (edited) When in neutral, i push clutch right in, and give it some revs. 3500-5000rpm it grinds. Even when its in a gear and clutch right in, rev and it grinds. And when driving, changing gears at high revs grinds. If i let revs drop to 2000-3000rpm its no worries. 1993 nissan skyline r33 GTsT. Manual, single turbo. RB25DET. Edited November 29, 2017 by BenjaminHJ93 Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/ Share on other sites More sharing options...
GTSBoy Posted November 29, 2017 Share Posted November 29, 2017 So don't do those things? 1 Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7860663 Share on other sites More sharing options...
Dobz Posted November 29, 2017 Share Posted November 29, 2017 What happens when you don’t push the clutch in and then rev it? Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7860713 Share on other sites More sharing options...
Humbla Posted November 30, 2017 Share Posted November 30, 2017 Oh dear. ? Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7860781 Share on other sites More sharing options...
BenjaminHJ93 Posted November 30, 2017 Author Share Posted November 30, 2017 Dobz.. it doesn’t grind when clutch not in. Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7860798 Share on other sites More sharing options...
BenjaminHJ93 Posted November 30, 2017 Author Share Posted November 30, 2017 Gts boy, its not being drivin at the moment, just waiting for a couple more pays until i take it into my mechanic, just want an idea of what it is. Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7860800 Share on other sites More sharing options...
BenjaminHJ93 Posted November 30, 2017 Author Share Posted November 30, 2017 Humbla.. get out of here ? Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7860801 Share on other sites More sharing options...
GTSBoy Posted November 30, 2017 Share Posted November 30, 2017 It's something between the flywheel and the mid plate of the gearbox not healthy. Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7860834 Share on other sites More sharing options...
Die$eL Posted December 1, 2017 Share Posted December 1, 2017 what if you pump the clutch a few times before doing any of that? Does the clutch engage very low/very high? Try bleeding the clutch system. Even better replace the clutch fluid and bleed out the old fluid Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7860971 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 14, 2017 Share Posted December 14, 2017 adjust the rod of your clutch pedal and/or maybe the bolt that controls the height limit of the clutch pedal. Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7862366 Share on other sites More sharing options...
BenjaminHJ93 Posted December 29, 2017 Author Share Posted December 29, 2017 Got it all looked at and replaced, bad throw out bearing. So i got a complete clutch kit installed. [emoji106] Link to comment https://www.sau.com.au/forums/topic/472796-r33-gtst-clutch-transmission-high-revs-grinding/#findComment-7863588 Share on other sites More sharing options...
