Hey guys just joined, been using the page for awhile very helpful thanks. As title states unsure if power figures are low or normal/expected.
I've had my head rebuilt (will post Pic of cam specs) camtech cam, 1mm oversized stainless steel valves, Port & polished, new lifters, cracked tested, match ported manifold etc. Stock bottom end
Bolted everything together took it in for a nistune and dyno tune, had a few minor issues. He finished the tune ended up with 108kW and around 240nm.
Just thought it would produce more kW with the head work.
Mods: rebuilt head, match ported manifold, 6-3-1 extractors 2.25inch straight though, believe hifow cat, nistune, k&n podfilter
Thank you
RB30E with a cam and extractors.  If it made a genuine 120rwkW you'd have to be satisfied.  Not far short at 108.  Guessing it's all done at 5000rpm?
It's a lot harder to make NA hp, and it's going to involve compression, proper fuel eg E85, lots of revs and light components that rotate and reciprocate.  Toss out the 2 valve head and get a 4 valve.  Multiple throttles inlet, and then find someone who understands inlet tract length, header design, and cam spec/timing.
Presuming you're in love with NA RB engines.
Differently not disappointed with the power, just wanted abit more torque and kW's as I'm hoping to get into hill climb/time attack, I was thinking around 120rwkw but like you said not to far off. Yeah on the dyno sheet all done by 5000rpm.
Yeah nearly everyone I've spoke to has said go DOHC or turbo but I wanted to keep the SOHC and remain NA, ahaha yeah don't know why just not a fan of turbos in my cars, driven a hand full and their fun to drive just rather NA.
Just got into RB's so pretty much a learning experience, pretty much just been into rotarys for the last 10 years. (I'm only 23)
I started motorsport in rally, navigating in a R31.  There's nothing wrong with a good NA.  It's just that a 2 valve RB head is nothing at all special.
The whole thing can be made better ie able to breathe and make the torque at higher rpm with a 4 valve head. Depends how much you want to go down that path, and what the budget is to make things less wrong.
Big heavy NA RB won't go through twisty hillclimb stuff that easy, and you'll need a sun dial to time it for Time Attack.  But you could certainly have fun.  Fatz evidently had a whale of a time in 24 hour Lemons event with his R31.
  • Haha 1
Get a RB25DET NEO head on it, bring up the comp to about 11:1, put massive cams into it and rev it to the moon... could even adapt ITBs to it.
A high comp, 3.0L, NA with ITBs and VCT would be pretty fun.
And as Bill said, nitrous.. I would spray nitrous into it.
I recently got 130rwkw from a n/a RB25/30 with Tomei cams, pod filter, good exhaust no extractors, 10.5:1 comp. You could spend approx 3k on head and cams and only really get another 20kw. I’m looking for a Supercharger
A decent L series with LD 3.1 stroker crank and LOTS of attention to detail with all the right bits to achieve airflow might struggle to do better than 210rwhp (say 165rwkW).  There's a fairly serious spend required to get there, and a lot of revs that sacrifices low rpm torque.
One of those IMO is a spiritual father to a 30DE donk.
I think a 30DE build as you've described is pretty good if it made 130rwkW while retaining a dirty old cast manifold.  I'd guess it did its best before 6000rpm too.
If you wanted to play up around the 8000rpm mark there's a fair bit of engineering magic required: complete inlet tract, porting, cam profile and timing, complete exhaust tract, and I'd say a proper crank trigger kit to avoid timing scatter.  Notice that's all airflow related.  You'd still want pistons/rods/fasteners/proper valve springs, retainers, light buckets/light flywheel and balance the lot.  And a properly thought out oiling system.
N/A horsepower doesn't come cheap.  But it can be very effective when done right.  Look at the BMW M3 engines, particularly thinking the 3.0 and 3.2 litre I6.
Yes they are expensive, I know a guy with a stroked L-series in his 240Z producing 220rwhp that cost $25k to build.
My 30DE peak power was at 5800rpm,  and I will be replacing my dirty old cast manifold with some extractors and new exhaust soon.
Will I need a re-tune for extractors and exhaust ?
Two things I'd suggest before spending up on some extractors.
First, establish what you want the engine to do, what rpm range you are going to find acceptable (implicit in that is the gearing you have, and whether a diff ratio change is necessary or desirable), and what $$ cost you want to limit this upgrade to.
Second, find a competent engine builder who understands RB heads. ( I'm hesitant to recommend any particular builder, but suggest The Mafia might be able to help with a name. )  Depending on their advice and your budget,  you should review those cam specs and decide to either replace or re-time the Jap cams.  Your head may require porting modifications (and I've seen instances where there was material added into an RB port to improve flow).  At the very least those cams should be properly degreed for the outcome you want.  Not a guessing game.
Then find who is going to build those extractors for you. (unlikely there will be any off the shelf for an RB twin cam).     They should establish the diameter/length of the primary and secondary pipes, plus the diameter of the system being built, based on your goals and some critical spec details on the engine.  There is a handful of people in the country who are properly competent in this area, IMO.
Once that's done, you're probably heading towards an engine spec where things are designed to work together.  And yes, you should then be looking to have the tune sorted so that fuel and ignition are working with the airflow characteristics of the engine.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
