okay so i just purchased GENUINE momo wheel (rip wallet) and i knew what i was getting myself into but not to this extent, there was this thing called airbag that i totally forgot and a "indicator cancellation) if i buy a HKB BOSS KIT ON-229, would it fix the airbag and indicator issues? i have been searching the web for hours but no clear answer
heres the link
https://www.amazon.co.jp/HKB-ON-229-SPORTS-ステアリングボス/dp/B00IQ2XX58
http://www.hkbsports.com/product/boss/nissan/nissan.html
i am in japan right now and can change or buy parts pretty much instantly so replys now would be great ! thanks so much
summary:
Would the HKB boss kit have indicator cancellation AND airbag light bypass?
thanks alot !
https://www.sau.com.au/forums/topic/472817-momo-hkb-boss-kit-help/
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
