I can never find any solid information regarding this turbo and the RB25Det.
So in the next few days I will be having one fitted to my car and tuned. Dyno sheet will be uploaded as well.
My mods are,
GARRETT GT3076R-56T G2 TURBOCHARGER T3 INTERNAL WASTE GATE
TURBINE HOUSING 0.82A/R
AEROFLOW BILLET EFI FUEL RAIL NISSAN RB25
Aeroflow 100psi oil filled gauge
Bosch 1000cc top feed
Turbo smart FPR800
Walbro 255HP pump
Relay mod for the pump and earth mod
Splitfire Coils
NGK BCPR7ES-8
FFP
Front mount intercooler
K&N air intake
Z32 AFM
Apexi power FC with hand controller
Autometer boost gauge
exhaust is 3" straight through with 1 rear muffler
Internal mods unknown
*Note engine bay photo is a before photo. After photo to come with dyno sheet update
Factory fitted sunroof, GTR wing, N spec body kit, front and rear strut braces, coil-overs
and more. It's only done 125,000 kms not bad for a 1994 model.
  • Like 2
https://www.sau.com.au/forums/topic/472823-garrett-gxt3076r-gen2-on-my-r33/
Keen to see some results from the GEN II 3076. Should do 300rwkw on 98. I assume you're not going E85 with a little walbro 255? To get the most out of a GTX you'll wanna be running E85 and pump some boost through her :)
My old school GT3076R-WG makes 500.9whp on E85 20psi boost with headgasket/studs/cams, stock bottom end. Previous tune with completely unopened motor was 286rwkw on 98 18psi and 325rwkw on E85 22psi.
Mine is external gate on CRG highmount mani also.
results !
conservative tune as I have now maxed out the AFM time for a map sensor setup to take it to the next level. Im also going to need a new boost gauge as that has maxed out too.
Im very happy with the results and how it drives on and off boost. It will how ever take time to get used to driving with this new setup.
C-Red did a amazing job with everything.
Looks like mine did about the same. I wont be able to go to E85 there is no where close to fill up. Over here in W.A we only have 6 servos that sell it in Perth metro.
I was advised that I'm now restricted by the AFM and the exhaust manifold. I was only aiming for 15psi but as I have found out this turbo loves the boost.
8 hours ago, Dale FZ1 said:
Should prove to be a good combination Craig.
Next stop, upgraded clutch to handle the mumbo.
looks like it held up no issues. It was previously a track circuit car the suspension is still setup for it and other things on the car.
Nice work, I was expecting better numbers than that especially with that sort of boost :/
Exhaust manifold isnt restricting, theres heaps of boys running a lot more power than you on stock manifold. AFM would be but I thought they could go a bit more than that. If you have the coin replace the dinosaur ecu and get a link/haltech whatever your tuner prefers and piss the afm off as I'm not sure you can upgrade unless you go to an R35 one but not sure if the PFC can use them or not.
  • Confused 1
Lots of fake Z32 afm's out there....either that or its not a Z32 afm.
Mate, I can sell you mine which is genuine & brand new for $300 flat including an apexi power intake filter (also brand new).
Z32 is good for 330-350kw.
I think thats theres a lot more too it then just the AFM getting close. I will have to have a chat to the tuner and find out what other things where happing while it was being tuned.
I do remember him saying that the coils may have had issues but i am running the splitfire one's could also have been the coil module.
Spark plugs could have also been letting it down although they had just been replaced.
Also the weather temp this day was in the 35+ degrees so this is also a big factor to the out come of the HP.
I am very happy with the way it drives on and off boost. I fully trust the tuner and he has been doing it for a long time his dyno is known to read lower then other dynos. How ever when I get a chance I will put it onto another dyno for a power run to see what it is.
On another note here is a few pic's of the dump pipe.
I agree that something isnt 100% how ever i do trust the tune.
I have also had thoughts about the PFC being old tech and would like to go to something like a Haltech. The tuner said that it would be my next step among other things if i wanted to get more power and remove the AFM.
Considering its internal gate, i think the result isn't too bad at all. If you where to go external off housing or even better, the manifold you would get a fair gain. Since e85 is a no go for you, you could consider water/meth injection. trevz in wa runs it on his 33 and ute i believe, you could get some pointers from him if you wanted to investigate that route.
The GTX76 mm is best working externally gated, I believe it is too big to be carried with an 60mm GT30 turbine wheel internally gated. In many cases you probably won't notice much of a power differences running this turbine setup internally gated on pump fuel with a GT71mm GT76mm GTX71mm and GTX76mm except the bigger wheels are comparatively laggier. The best way of taking advantages of the extra compressor flow would be running an external gate to your factory exhaust manifold.
  • Like 1
I’m about the fit the same turbo all Be it will be on 6 boost and external wastegate, top mounted, on 98 Ron to a unopened rb25 neo, also power F.C.  Intend to run a r35 gtr afm probably in 4” tube
im still on stock inlet manifold, will that be a major hold back ? Or just a minor issue?
Also, do you need a external oil restrictor on these turbos for rb25 ?
Edited by Eager
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
