Hey guys,
currently doing a DE+T conversion, I have found this black canister mounted under my inlet manifold to have one of the small inlet pipes busted off. Wondering am I right in assuming it’s a vaccum canister? Secondly is this needed?, I am wondering what people have done when they go to a forward facing plenum.
see photo attached of the part. Thanks in advance.
https://www.sau.com.au/forums/topic/472826-rb25de-question/
It is a vacuum canister. I removed mine for a de+t conversion. If I remember correctly vacuum came from the inlet plenum to this and then out again to the variable air intake butterfly valve solenoid. Another pipe goes from the solenoid to the butterfly actuator. I diverted the plenum take-off to my boost gauge instead. And I disconnected all the tubes from the solenoid. So this was redundant for me.
https://www.sau.com.au/forums/topic/472826-rb25de-question/#findComment-7861919
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
